Results 1 to 2 of 2
Thread: Deep narrow irregular holes in plastic: what bit?
    Jan 2009
    India
    Hi everyone,
    I need to cut irregularly shaped holes in plastic (probably polyethylene or flexible PVC).
    The nasty thing is that the holes need to be 1 cm (1/3 inch) (ideally even 2cm) but sometimes as narrow in places as 0.5mm (a little more than 1/64 inch).
    What kind of cutting bit could do this, and how?
    I've seen drill bits this narrow, and I don't mind using an approach of drilling many contigous small holes instead of sideways routing. But I worry that because drill bits are conical at the tip, if the holes overlap too much the tiny drill bit will bend into the existing hole rather than cutting a new one.
    I'm totally new to the world of cutting bits and CNC. If I knew the right terminology I could google more on what sizes were available, but I don't ...
    Tiny, deep, cutting bits anyone???
    Thanks!
    Jonathan
    Sep 2006
    LAser, except you don't want to do the PVC in a laser
  1. Drilling deep 1/2" holes?
    By lukaslouw in forum General Metalwork Discussion
    Last Post: 07-29-2008, 10:08 PM
  2. deep drilling 2mm holes
    By kesparate in forum General Metal Working Machines
    Last Post: 09-16-2007, 12:57 AM
  3. Deep holes in 6061
    By racerdog in forum General Metalwork Discussion
    Last Post: 06-17-2006, 03:09 PM
  4. circular interpolation of small deep holes
    By rchprks in forum General Metalwork Discussion
    Last Post: 11-25-2005, 09:37 PM
  5. Drilling deep holes.
    By HSM Joe in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 05-13-2003, 01:14 PM
