Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > CNC Tooling
CNC Tooling Discuss CNC tooling here.
Old 01-05-2009, 09:27 AM
Arcticfox46 is on a distinguished road
Adjustable boring bar
I am looking for an adjustable boring bar holder
Machine: Nakamura WT150
Max RPM = 6000
2 holes – one is brass -- one is bronze
Hole size: .1565+/-.0001
Roundness within .00015
Live tool
Cross hole
ER-32 collet holder
I am currently using a Criterion TMT-0750 boring bar holder in an ER collet.
Solid carbide boring bar.
I am having a difficult time adjusting size.
I need a super precision adjustable holder so that I can adjust within at least .0001 – preferably adjustable to within .00005
Thanks,
Leo Voisine
Manufacturing Engineer
Mahr Federal Inc.
Providence, R.I.
Leo.voisine@mahr.com
401-784-3370
Old 01-05-2009, 09:40 AM
jcoats's Avatar
jcoats is on a distinguished road
http://www.cnczone.com/forums/showthread.php?t=70939 - is posting in multiple forums the exact same question going to get you a better answer?
Old 01-05-2009, 10:23 AM
HuFlungDung's Avatar
Moderator
Brass or bronze both machine easily (and accurately), but not with honed inserts and not with positive rake. Take any insert, grind the chipbreaker off (just enough to create a small flat spot on the top face along the cutting edge) and create neutral or negative geometry. The tool will likely cut accurately all day without replacement. IMO.
Old 01-05-2009, 06:14 PM
No I don't expect to get a "better" answer - just more exposure - or just simply an answer.
Do you have a problem with me posting the same question in multiple forums?
Do the forum rules prohibit multiple postings of a question?
Do you think there is something inherently wrong with multiple postings?
Or perhaps you maybe have some constructive help to the question?
Old 01-05-2009, 06:59 PM
muddobber76 is on a distinguished road
Talking Adjustable Boring Bar
So do you need an adjustable bar to be held in a ER-32 for a live tooling application? I have this problem on a routine basis. I really like the adjustable holders from KOMET that I use on the mills but they are like most others and do not offer anything in a straight shank that would work in a ER collet. It's all HSK type tapered stuff. If you are doing a hole on cylinder then you will likely run into clearance issues when indexing. My KENNAMETAL guy told me that he had something that would work but I haven't looked into it yet. I've been lucky and always been able to get away with interpolating endmills (shallow depths). Get in touch with a couple of the top tooling companys to let them know what your application is. Good luck and please let me know what and if you find anything.
Old 01-05-2009, 07:11 PM
Thank you - I will look into the KOMET
We didn't have much luck with interpolating the .156+/-.0001 diameter holes
I found a nice adjustable bore bar set up at Big Kaizer. It screws directly onto the ER32 holder.
I am also looking into the Kennametal tooling.
I did get the Criterion tool to work, but it takes some real fussing to get it there. I am hoping to find something a little more user friendly for my operators. We don't make much money by fighting with boring bar holders.
Is the slideway lubrication adjustable? mattme Mazak, Mitsubishi, Mazatrol 7 10-27-2008 08:18 AM
Adjustable Support Blocks ninthmp Linear and Rotary Motion 2 05-10-2007 04:59 AM
adjustable cams and pulleys krymis I.C. Engines 15 10-19-2006 08:04 PM
Adjustable preload- Will this work? spoiledbrat DIY-CNC Router Table Machines 0 05-15-2005 12:12 AM
Adjustable Reamer Question Joe_CNC General Metalwork Discussion 6 11-07-2004 08:27 AM
