Results 1 to 3 of 3
Thread: Looking for a RotaBroach / Annular Cutter CT 40 Tool Holder
    Feb 2008
    I just purchased a Hougen RotaBroach 12648 (1.500"dia x 1.0doc) with a 0.750 shank with two weldon flats at 90deg to eachother.
    The problem I am having is finding a tool holder for the cutter. The center of the weldon flat is only 0.500" from the top of the tool. All of the endmill holders I've found with a 0.750" hole have a set screw that is 1.000" from the bottom of the holder.
    Any help would be much appreciated.
    Apr 2005
    Paradise, Ca, USA
    If the tool has a long enough shank, just grind your own flat on it. I do this to carbide endmills when needed. The flat doesn't need to be nearly as large or as deep as they generally are supplied. I have a 3/4" carbide endmill that I regularly run at 130% spindle load on a 20hp Haas that has a flat that's probably only 1/16" deep, if that. It aint pretty either, but it sure works well.
    Feb 2008
    Thanks for the reply. The problem was that the shank was really short, so grinding it was out of the question. After some digging through McMaster I found an arbor adapter 31315A254. We haven't used it yet, but it looks like it should work nicely. It comes with a spring installed to have a pilot/ejector installed, but we removed it so we can use TSC.
    Thanks again,
    Mike Hoyer
  1. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 05:15 PM
  2. what is this tool holder for
    By bassmastrbw96 in forum CNC Tooling
    Last Post: 09-06-2008, 10:11 PM
  3. T slot tool post with drill bit tool holder
    By brucesu1 in forum CNC Tooling
    Last Post: 06-09-2008, 06:04 AM
  4. How do I use a dove tool cutter & slot cutter
    By bobby1 in forum BobCad-Cam
    Last Post: 04-15-2008, 09:06 PM
  5. Need Help!- Slot Cutter Holder Arbor type, cant find??
    By mgb1974 in forum General Metalwork Discussion
    Last Post: 03-10-2008, 08:36 AM
