| CNC Tooling Discuss CNC tooling here. |
I wonder if there is some kind of tooling for a cnc mill to allow grinding and polishing? If there is can you please point me to the site or manufacturer from whom I can get it. Thanks! |
I am machining aluminum air cylinders and am looking for the same type of product. I have also been looking for something like a burnishing tool that can be run as a finisher on the walls, since my cylinders are not round a standard burnisher will not work. I am looking for any suggestions. |
Have you consider using a high frequency spindle or spindle speeder to give you the rpm: http://www.mctooling.com/index/listings/page862.htm |
| Are you thinking something along the lines of a rubberized abrasive wheel or stick? Such as: http://www.cratex.com/rubindx.htm It reminds me of the old electric drafting erasers. They used to have some eraser sticks with abrasive for erasing pen and ink drawings. Maybe they still do. |
| I got a hold of a company in Grand Rapids, MI called C.B. DeKorne that got me a bunch of samples of things to try, and I found that felt bobs work pretty good for polishing parts in a machine. As long as you apply some compound the walls of the part and program the bob to have about .01-.015 of side load. The other thing that I tried that worked fairly well was some little scotchbrite wheels that we ordered from J&L Industrial Supply. Those come in a variety of different abrasive levels. I hope this helps. |
| Grinding Cam profiles on a DeskCNC 4 axis mill | Paraprop | Carken Products (Deskam, DeskCNC etc) | 37 | 05-01-2009 09:58 AM |
| cutting die to cut abrasive cloth? | Syphonics | General Metal Working Machines | 3 | 11-21-2008 09:15 AM |
| Turning A Grinding Wheel | drill | Mazak, Mitsubishi, Mazatrol | 4 | 02-06-2006 07:24 PM |
| Grinding flat surfaces on vertical mill? | Cowbell | Benchtop Machines | 3 | 01-17-2006 10:59 PM |
| 5 axis Abrasive WaterJet | Lesh | General Metalwork Discussion | 2 | 09-18-2005 12:39 AM |
