Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > CNC Tooling
CNC Tooling Discuss CNC tooling here.
Old 08-07-2008, 01:38 PM
sopwith is on a distinguished road
Kress and Isel router spindles
I have take delivery of an Isel UFM1050 spindle along with a number of collets of various sizes. I bought the spindle and collets from the same supplier. The collets on the web site came under the heading of collets for Kress and Isel, from this and and information I had googled lead me to believe that Kress and Isel collets for the 1050 series are interchagable, however when these collets are placed in the UFM1050 collet nut (a tight fit) they close up and do not allow the shaft of the correct size cutter in. My question is does anybody know if the collet nut of the Kress FME1050 will fit onto the spindle of the UFM1050 (I am assuming that these collets are for a Kress) this would be a nice solution as Kress collets are easier to obtain (and are cheaper).
Thanks Robert
Old 08-20-2008, 09:08 AM
As I received no replies to my question I bought a Kress collet nut and no it does not fit the Isel spindle (greater OD).
Thanks Robert
Old 12-26-2008, 08:24 PM
j.c.freeman is on a distinguished road
Isel spindle
I have just bought the same spindle motor and have the same problem, did you sort it or find a supplier that doesn't charge the earth.
Old 12-29-2008, 05:35 PM
No the only solution I found was to hold the Kress collets in a lathe with the correctly sized shaft inserted and then to hone down the diameter of the front angle.
Kress 800w router Bernard HURCO 10 01-28-2011 07:43 AM
Build Thread- Kress Router...any good! flyboypete DIY-CNC Router Table Machines 8 10-12-2010 06:58 PM
Need Help!- Hi, I'm new here, and need some help with KRESS router Tadas25 DIY-CNC Router Table Machines 4 07-08-2008 12:52 PM
kress router brianna187 Want To Buy...Need help! 0 04-28-2008 10:23 AM
Floating head on Kress router zoltan Mechanical Calculations/Engineering Design 3 03-02-2007 07:52 AM
