Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > CNC Tooling
CNC Tooling Discuss CNC tooling here.
Old 04-16-2008, 08:02 AM
SKEETO's Avatar
SKEETO is on a distinguished road
Talking 1'' Fly Cutters
We are looking for a cutter with through coolant for roughing out a pocket: 1.753 ID x 2.435 depth. We are using a 1.625 core drill then spiralling down with a 1'' cutter. Chip evacuation needs to be good. We are currently using a Mitsubishi cutter. Works OK but looking for sugestions. Thanks in advance.
Old 04-16-2008, 08:31 AM
cadman@teluspla is on a distinguished road
We use 210 coromills and 390 coromills
both work very well
you will not need to drill a starter hole with either one
Just have to watch that your ramp angle is not to steep, use sandvik spec's and they work
Old 04-17-2008, 05:33 AM
5axisguy is on a distinguished road
We just had a demo on the Mitsubishi and on the Hitachi, and the Hitachi just smoked the Mits. The mitsubishi ran very rough and hammered compared to the Hitachi. We ran a 1" on some H-13 on one of our smaller hurcos. We took a .031 depth of cut .70 wide at 350" per minute, about 1950 rpm's. I ran quiet and smooth for about an hour before we were finished with the block, the insert wear was basically nothing, just a slight shiny edge, it could have easily gone 3 times the time. I does have thru coolant or air. We are replacing all our Iscar tools with them.
Fly Cutters? BrendaEM Benchtop Machines 19 03-11-2007 08:32 PM
How to tell what cutters go with what? ZipSnipe Benchtop Machines 23 04-06-2006 12:55 PM
Cutters? atemylunch DIY-CNC Router Table Machines 4 05-11-2005 11:56 AM
Cutters pminmo DIY-CNC Router Table Machines 7 01-03-2004 02:09 PM
Solid cutters HuFlungDung OneCNC 4 04-23-2003 03:41 PM
