Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > CNC Tooling
CNC Tooling Discuss CNC tooling here.
Old 03-08-2008, 08:29 PM
mredican's Avatar
mredican is on a distinguished road
Need some direction...
I am goint to use a Porter-Cable Laminate Trimmer on my cnc. I was using a dremmel but that was too small.
Anyhow, I am going to cut mostly maple and spruce wood parts. I need end mills for roughing and finnishing but have become confused by all the selections. Here are some questions:
Do I need to purchase an end-mill holder?
For wood should I use 2 flute or 4?
Is it possible to attach a 1/2 inch end mill to this laminate trimmer set up?
Best place to buy?
Sorry, lots of questions.
matt
Old 03-08-2008, 08:40 PM
blackbeard52 is on a distinguished road
porter cable laminate trimmer
Matt
I dont believe that Porter Cable supports a 1/2 laminate trimmer. most are 1/4 and come with sufficient collets to hold a router cutter that will do the job. Keep in mind that those trimmers are not the HP of the bigger guys and plunge cuts are not recommended on thick stock. Having said that, Most are using a spiral flute upcut router bit usually in 2 flute as the relief depth is greater and the cuts will not burn or walk as bad.
Hope this helps.
Bob
Old 03-08-2008, 09:37 PM
ger21's Avatar
You'll want to use spiral router bits with a 1/4" shank, like these. http://eagleamerica.com/product.asp?...cd2=1205033524
You can also get carbide tipped router bits in larger diameters with 1/4" shanks, but you'll need to take shallow passes due to the low power of the laminate trimmer.
The laminate trimmer will come with a 1/4" collet to hold these. You might want to look at the Bosch Colt, which is variable speed and a little more power. Laminate trimmers spin at very high rpm's and can easily cause burning of the workpiece.
Old 03-09-2008, 08:39 PM
mredican's Avatar
Thank you guys. Excellent information that will get me up and running. I would like to go with a larger router; however, I am concerned that the extra weight will put too much load on my stepper motors.
Motor Direction Ken Bond Phase Converters and VFD 2 11-20-2007 06:22 AM
Looking for some direction Tristanc1 General Metalwork Discussion 5 05-27-2007 01:00 AM
Spindle direction deji Haas Mills 9 02-23-2007 11:53 AM
Stepper only going in one direction? ScuD Stepper Motors and Drives 7 12-09-2005 05:28 AM
Looking for Direction on Retro.. stang5197 Bridgeport and Hardinge Mills 5 11-24-2005 09:07 AM
