Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > CNC Tooling
CNC Tooling Discuss CNC tooling here.
Old 11-11-2007, 11:15 PM
DroopyPawn is on a distinguished road
Shorten My Endmill
I bought a couple of 1/4" endmills. What would be the best way to shorten one of them from 6" to about 3"?
Gary Shepherd
www.16tracks.com
Old 11-11-2007, 11:20 PM
DSL PWR is on a distinguished road
You will need to grind them.
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 11-12-2007, 06:12 AM
Boots is on a distinguished road
Shorten EndMill
The best way is to cut it off using a slitting saw. This is an abrasive cutting wheel that fits on a grinder. The thinner the better like .015 or .020 wd. These can cut Carbibe or HS Steel. You didn't say what type you had there. But either way you will have to spray a mist of coolent on the Tool as to not heat it up and destory it's temper. If you are cutting off the Tool where the cutting flutes are you will obviously have to resharpen the end.
Hope this helps you.
Old 11-12-2007, 12:48 PM
Ed VanEss is on a distinguished road
SHORTEN ENDMILL.
You have a .250 endmill 6" long? a standard .250 endmill is 3" long. Just get a standard single end .250 endmill.
Old 11-12-2007, 06:05 PM
Ed, it's a little later for that now.
Gary Shepherd
www.16tracks.com
What is an acceptable endmill tir? papa_rr Toolgrinding & Toolgrinding Machines 2 09-12-2010 04:39 PM
Need endmill advice for x1 simpleton Benchtop Machines 14 11-11-2006 06:44 PM
Endmill bit and holder. ihkim General Metalwork Discussion 0 07-26-2005 01:38 PM
When to use slotdrill or endmill. MrBean General Metalwork Discussion 4 03-20-2005 11:16 PM
Endmill runout dberndt General Metalwork Discussion 14 01-27-2005 11:26 PM
