Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > CNC Tooling
CNC Tooling Discuss CNC tooling here.
Old 09-13-2007, 09:32 AM
johnm99 is on a distinguished road
1mm endmills/bits
i realize a topic such as this is probably already posted but in my searches I have hit nothing but blanks... Please forgive me if I have overlooked any of the forums....
I am looking for a source on 1mm bits for cutting Acrylics or other plastics...
I have looked up MSC and a few other spots but nothing is coming up that will work...
I will try anything at this point... just looking for some direction...
Old 09-13-2007, 12:11 PM
big_mak is on a distinguished road
Try endmills that are designed for aluminum. They are sharp enough to cut the material and not hammer it out.
Robb Jack makes endmills that small. I can't remember off had if you can get the Garr 242M series that small
"It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
Old 09-13-2007, 12:15 PM
2muchstuff is on a distinguished road
Check out the carbide burrs that are used in the dental profession. The only thing is that they are 1/16" shank diameter. The oral surgery burrs are a bit longer in length. Here are a couple of suppliers.
http://www.sswhiteburs.com/carbide_burs_guide.php
http://www.microcopydental.com/neoburr.html
Or search Carbide Dental Burrs.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 09-13-2007, 03:54 PM
sorry double post
Old 09-13-2007, 04:00 PM
I'd be hesitant to try Burrs for cutting plastic, you need room for the chips to get out. Stick with 2 flute endmills and your material bill will thank me!
Old 09-13-2007, 04:40 PM
I agree, Acrylic is some soft stuff. The only reason I posted it was that they are small. The harder the plastic, the better the chip removal.
Old 09-16-2007, 01:23 PM
RedDog22 is on a distinguished road
Did a quick google search and found a few links
http://www.bitsbits.net/index.php?ma...roducts_id=248
http://www.endmilldiscount.com/end-m...l/pmt-tr-2.htm
After posting I found this too
http://microcutusa.com/
Old 09-17-2007, 12:19 AM
*Registered User*
fpworks is on a distinguished road
www.harveytool.com
VERY nice tools. I use quite a few of their endmills 0.030" to 0.050", stub length, 2 flute in aluminum.
Old 09-17-2007, 11:27 AM
JROM is on a distinguished road
If your working in a wood shop you use "bits"
If your working in a machine shop you use endmills or cutters.
There I got that off my chest..........lol
I cut alot of plastic in my shop and we use high helix three flute carbide endmills whenever possible. Your main problem is heat. If you let the chips stick to the cutter you will end up with a junk part and a broken tool. You would be suprised how much cutting fluid makes a differance when cutting plastic.
Be carefull what you wish for, you might get it.
Old 09-17-2007, 11:39 AM
We use alot of Garr brand cutters and sometimes Micrograin carbide.
Any good tool supply house should be able to set you up with any number of good quailty carbide cutters. Believe it or not the softer the plastic is the more trouble you will have trying to cut it. Soft plastic will squish out of the way and spring back and closeup the cut if you don't use very sharp cutters.
A word to the wise.............
  #11   Ban this user!
Old 09-17-2007, 12:24 PM
neilw20's Avatar
neilw20 is on a distinguished road
Smile PCB drills are small. Nice rout
Go to your friendly PCB manufacturer and get some worn out cutters/drills
Carbide will last much better. HSS in plastics get dulled very quickly.
What is worn out for fiberglass pcbs is still pretty good.
Router bits are very good also. PCBs wear them out too.
New Ones...
look here. Search google for PCB drills. A fwe links..
http://www.uniontool.co.jp/english/product_01.html
http://www.northbaytechnical.com/standard1.htm
http://www.megauk.com/carbide_drill_bits.php
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Last edited by neilw20; 09-17-2007 at 12:26 PM. Reason: typo, Carbide afterthought
Endmills okay for wood? phantomcow2 DIY-CNC Router Table Machines 41 09-02-2010 08:55 AM
Coolant Fed Endmills eorourke General Metalwork Discussion 10 06-21-2007 09:35 PM
Sharpening Endmills ADCORGUY Toolgrinding & Toolgrinding Machines 0 03-30-2007 07:55 AM
Working with Endmills Burn Benchtop Machines 13 05-16-2006 02:40 PM
Anyone used these endmills? Cold Fusion General Metal Working Machines 8 09-12-2004 11:16 PM
