Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > CNC Tooling
CNC Tooling Discuss CNC tooling here.
Old 09-05-2007, 11:49 AM
DrStein99's Avatar
DrStein99 is on a distinguished road
Using wood routers on CNC
I see there are lots of people building cnc machines that use trim routers and wood routers. Obviously this works well for wood.
Does anyone machine aluminum or plastics using routers? I was wondering how that would be possible with the extreme heat from the high rpms on that. I used coolant on a router job one time, and it worked. Days later I had to throw away the router because the bearings and armature had just enough rust to call it quits.
WWW.RAIDGEAR.NET - FFC cables, foam headset replacement parts, and other gadgets.
Old 09-05-2007, 08:44 PM
martinw is on a distinguished road
Dear DrStein99,
It is entirely possible to use a wood router to machine aluminium if (1) you use the correct type of carbide or HSS bit (2) use the correct rpm for the cutter (3) take really light passes (4) use a good lubricant, (paste wax works) and (4) last not but least, cover the ventilation slots of your router with some of your partner's discarded nylon stockings ( or whatever) to stop the swarf getting into the motor.
BTW....I'm not entirely sure if this advice would work in a production environment ...
Best wishes
Martin
Not Wood but works like wood almost foamcutter WoodWorking 8 07-12-2005 04:14 PM
CNC Routers IndianaDav DIY-CNC Router Table Machines 1 07-07-2004 07:27 PM
Suitabilty of recirclating ball linear slides with cnc routers (wood cutting) twombo DIY-CNC Router Table Machines 5 03-03-2004 07:35 PM
Dremel Based Wood Routers Mhiran DIY-CNC Router Table Machines 5 11-08-2003 10:39 PM
damn wood routers sdwilson Mastercam 3 08-15-2003 09:15 AM
