Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > CNC Tooling
CNC Tooling Discuss CNC tooling here.
Old 08-29-2007, 12:30 PM
jim_stoll is on a distinguished road
Tool for cutting Step Block steps?
I'm new to cnc and metal working in general. I've got a Taig cnc mill and have been playing w/ it for a while. I recently ordered a small step block and clamp set - very handy, and I could see myself using a wider variety of clamps on the blocks, but I need relatively small stuff for the Taig (ie, the sets from Enco won't work, for example). Has anyone ever cut their own steps? (ie, on the end of the clamp to fit onto the block). What would I use to do that, some type of angle-edge slitting saw or such? I don't need to make blocks, just the clamp bars. If this is a fool's errand, feel free to tell me so - I don't know any better at this point! (and truthfully, anything that I spend time making is an education for me, so I'm kind of hunting around for small projects...)
Thanks for any help/info!
Old 08-29-2007, 12:39 PM
I suppose I could also use a dovetail cutter? Is there a 'standard' step angle/depth/etc?
Old 08-29-2007, 01:09 PM
HuFlungDung's Avatar
Moderator
I checked my clamping sets, the included angle could be cut with a 60 degree dovetail cutter. The bottom of the cutter would need to be tilted 15 degrees off of horizontal to correspond to the sets I use.
They appear to have 8 teeth per inch.
Old 08-29-2007, 01:11 PM
Awesome - thanks for the detailed info HuFlung. (love the name!)
Now I just need to find a 60deg dovetail cutter that will fit in my pre-ER16 Taig!!
How much power at the cutting tool? Oldmanandhistoy Benchtop Machines 9 06-02-2007 06:23 PM
Cutting Tool Suggestions Jonathan3520 Shopmaster/Shoptask 3 11-10-2006 11:28 AM
Full Steps -vs- Micro Steps DJB282000 General Electronics Discussion 10 12-28-2005 11:25 PM
RS232 program block by block smoregrava General CNC (Mill and Lathe) Control Software (NC) 3 12-22-2005 12:52 AM
Best tool for cutting metal? PsyKotyk General Metalwork Discussion 4 04-01-2004 02:10 AM
