| CNC Tooling Discuss CNC tooling here. |
Was wondering if anyone could suggest a good indexable endmill and insert combination that will stand up good agains 316 ss. Our shop makes these large perforated stainless steel discs which have a number of bored holes in them. Holes can range anywhere from 2" to 4" diameter. We currently drill the holes with a 1.875" drill (largest our machine will push safely) and then plunge out most of the material using a Kennametal RPF cutter and then interpolate it with the same cutter. Finally we finish bore the holes to around +/- 0.003". The Kennametal tools is the best we've found so far for plunging and interpolating, however the inserts don't last all that long. I was hoping to find a tool that, after drilling, we can use as a high SFM and small chipload to remove the material faster than plunging. The depth of the holes vary depending on the disc size, but they are typically as deep as they are wide, so would need a tool capable of reaching 3" deep or more, but with a length of cut that would prevent us from doing 10 depth passes. Any suggestions? Thanks |
| try this http://www.lovejoytool.com/ any of these big company's offer on the phone tech support and sometimes will come to your shop to setup there tools |
| holbieone's link shows a Lovejoy similar to the Ingersoll. It's the end mill with the long inserts. Iscar makes one similar to that also. All the carbide salesmen must have something similar by now. The application people at the carbide companies can give you the correct grade for their tools.
__________________ DZASTR |
| cutter style: Hi Pos+ series 22J3E Inserts: AOMT 180508R GRADE: look for something around the 1030 grade Flush with coolant This will do your cutting after the hole is drilled http://www.ingersoll.com/ictc/promo/...PerfPakP14.pdf for more info
__________________ Rules of my Road: Don't do what you will regret! Never regret anything you do! |
| We pocket and rough bore 316 with Sandvik R210 feedmills. Finish bore with a boring head and forget the drills. Insert grade 2030 positive rake stainless insert. 700 SFPM, .035 DOC, .035 feed per tooth for the #9 insert. Same SFPM but .04 DOC and .045 feed per tooth for the #14. About 30 minutes cut time before indexing 180 because you loose 2 corners when your up against a wall. Run dry with air to clear the chips. Best we've found yet. Mike |
| If you are machining through holes, take a look to the trapaning drill bigger Tysontool is offering, we got really good results with them. direct drilling plus finishing boring head without the need of milling and plunging http://www.tysontool.com/trepanp1.htm |
| Indexable tooling | Davidimurray | Mini Lathe | 2 | 11-18-2006 09:46 PM |
| Name This Indexable Drill | JFettig | General Metal Working Machines | 8 | 05-08-2006 01:26 PM |
| RFQ - water/laser jet 316SS | zcases | Employment Opportunity | 2 | 01-09-2006 04:39 AM |
| Cutting 4mil 316SS | ChrisJ | General Metalwork Discussion | 3 | 07-20-2005 02:01 PM |
| Indexable Head ?? | rcazwillis | General Metalwork Discussion | 8 | 05-31-2005 09:01 AM |
