Go Back   CNCzone.com-The Largest Machinist Community on the net! > Tools and Tooling Technology > CNC Tooling
CNC Tooling Discuss CNC tooling here.
Old 11-01-2006, 10:42 AM
H2ODiver is on a distinguished road
Porter Cable 890 Router and collet
I have a porter cable router (890) hooked up to a K2CNC machine and was wondering what sort of mechanical tool presetter I can use to maintain repeatable tool height. I emailed Tormach but they said they did not have anything to fit this router. The Porter Cable can utilize 1/4 and 1/2 shafts.
Is anyone using anything that would fit this configuration?
Old 11-01-2006, 05:23 PM
ger21's Avatar
If using Mach3, you can make an automatic height setter like this. http://www.cnczone.com/forums/showthread.php?t=26607
Old 11-07-2006, 05:50 AM
Thanks for the info, I will look into this.
Old 01-20-2007, 07:21 PM
spoiledbrat is on a distinguished road
892 collets
I know this is probably one month late, and possibly the wrong size bits, but here goes.
If you are using a home or limit switch on your Z axis, the router can be trusted to be in the same place today, tomorrow, and next week when you type in G1 Z0.5". That being said, if you can find someone to make these toolholders for you in their lathe, you will not have to use that blasted toolsetter ever again. The 892 router collet has a taper in it that assures you of a repeatable tool height each time you put the tool in. The tools are simply placed withing the toolholders using Loctite, and the old collet nut and snap ring are used. You will find that if your taper is correct, once you loosen the nut, the taper will hold itself in until the nut begins to push down on the snapring (see OEM collets)
I have been using this setup for the last three years, and the only time I have to measure a tool is when I am replacing a broken one.
The tool table in Mach 2 has all of my offsets stored for me.
I only write this to help. Sorry if I missed the mark.
Name:	892 collet tools.JPG‎
Old 01-20-2007, 08:33 PM
Thanks for the reply Spoiledbrat,
The setup you have described is what I have been using since my last post. Your right... this setup works great and is very fast and repeatable.
Thanks for your feedback!
