Results 1 to 4 of 4
Thread: Help: 2mm drill in 1/4" collet
    Feb 2005
    New Zealand
    Question Help: 2mm drill in 1/4" collet
    *** Yes, I know I shouldn't do this. ***
    My hobby cnc mdf router has a Ozita router as the "spindle", fitted with a 1/4" collet for standard router bits.
    I need to drill a number of 2.0mm and 2.5mm holes in some thin mdf, using the cnc to get accurate placement. (It's actually a part for a 3d printer).
    Now I realise that a HSS drill spinning at far_too_fast won't work brilliantly, but I don't have any 1/4" shank router bits smaller than 3.2mm. This will all take place inside a very solid enclosure so if something explodes I don't expect any human damage.
    Shall I:
    (a) Turn a chunk of steel to 1/4" diameter, drill into it with the 2mm held in the tailstock, then solder the drill (possibly shortened) into it.
    (b) Turn a chunk oversize, drill into it with the 2mm, solder in, then hold the drill bit in the chuck and turn the shank down to 1/4" to try and get it more concentric.
    (c) Make a sleeve, 2mm ID, 1/4" OD, slit down one side, and clamp the drill with that.
    or (d) Turn a sharp point on a chunk of 1/4" steel (or grind it on some hardened music wire), and use the cnc z-axis to drive the point into the mdf, then use the indentation as a guide to drill the holes in a drill press?
    Withering criticism, helpful ideas, or any comments welcomed.
    May 2008
    They're a lot of mini chuck or micro chuck you can buy anywhere like amazon.
    http://www.amazon.com/SE-Micro-Chuck-inch-shank/dp/B001NQP8HU%3FSubscriptionId=AKIAJ2KCCSRYBYAUNNMA&tag=affilamazo0da-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B001NQP8HU]Amazon.com: Micro Chuck 1/4 inch shank: Home Improvement
    1-3mm Mini Micro Drill Chuck Pin Vise Set 1/4" Shank | eBay
    Or look for Dremel chuck, very inexpensive.
    Hope this help.
    And don't use anything that is not balanced to high speed.
    Jeff
    Attached Thumbnails Attached Thumbnails Help: 2mm drill in 1/4" collet-micro_chuch.jpg
    Feb 2005
    New Zealand
    Wow. Thanks Jeffrey.
    I had assumed (bad me) that anything of that type would be too expensive. I've ordered a unit of ebay - much more professional than my bodge would have been.
    May 2004
    Or there are adapters available to run smaller drill sizes in 1/4" holders.
    http://www.kirkcon.com/
  1. What's the difference between "drill rod" and "plated steel rod"?
    By Robotics Guy in forum Linear and Rotary Motion
    Last Post: 02-05-2011, 11:16 PM
  2. Hardinge Collet, Tap Adapter and Drill Bushing Tray
    By HelicopterJohn in forum Hardinge Lathes
    Last Post: 04-22-2010, 09:54 AM
  3. Using collet instead of drill chuck? for drilling steel
    By Rich05 in forum General Metalwork Discussion
    Last Post: 07-13-2008, 11:53 PM
  4. I need a drill collet
    By CNCadmin in forum Benchtop Machines
    Last Post: 04-06-2003, 12:35 PM
