Results 1 to 3 of 3
Thread: Haas 4th axis indexer - removal (dumb question)
    Registered zcases's Avatar
    Apr 2005
    I just purchased a machine with a HAAS 4th already on it. And, I htink its been on it for a couple decades. I wonder if I am missing something or if the decades old dried oil is bonding it to the fixture plate.
    Is there some hidden fasteners under the casting? Or are the two fasteners visible all that is mechanically holding it?
    I really want to remove it until I am comfy with the new control, for obvious reasons. And actually I dont see myself making good use of a 4th in the forseeable future, if there is any interest in it.
    Scott
    http://www.scpconcepts.com
    Jul 2005
    Ther are tapped holes on the bottom of the rotary housing. Can you get the fixture plate off to see if it is also bolted through these holes.
    Apr 2005
    Ahhh...thanks Geof. I will take the fixture plate/4th off together and take a look underneath.
    Scott
  1. Dumb question, but not so dumb??
    By gixxergary in forum Haas Mills
    Last Post: 01-09-2012, 07:30 PM
  2. Need Help!- Haas indexer question
    By caddisfly in forum Haas Mills
    Last Post: 03-22-2011, 10:36 AM
  3. haas indexer
    By Jfrahm in forum Fanuc
    Last Post: 12-15-2010, 03:13 PM
  4. Haas Indexer as full 4th axis
    By WGJ in forum Haas Mills
    Last Post: 12-24-2009, 04:42 PM
  5. Haas Indexer
    By binzer in forum Haas Mills
    Last Post: 12-15-2009, 09:10 PM
