Results 1 to 2 of 2
Thread: Router Starter Set
    Registered anthropod's Avatar
    Jul 2010
    Router Starter Set
    I am new to CNC routers. I have on order my first CNC router and am really excited. Tooling is something that I really overwhelms me.
    I have seen other similar threads, but did not find a good answer/discussion.
    What would be a good starter set of tooling to make the CNC router useful.
    I would like to make lithophanes, some signs, and cut plastic sheets into RC parts.
    I saw a list of tooling on another thread but didn't see any real comments.
    End Mills
    End Mill .25 inch
    End Mill .5 inch
    Ball Nose
    Ball Nose .25 inch
    Ball Nose .125 inch
    V-Bits
    V-Bit 60 deg .25 inch
    V-Bit 90 deg .5 inch
    V-Bit 90 deg 1.25 inch
    Engraving
    20 deg .02 Tip
    Would this be a good starter set?
    Is there something missing?
    Is there something not needed?
    Mar 2003
    Shelby Twp, MI....USA
    I'd recommend buying what you need, and not really a "set".
    For Lithophanes, you'll want a 1/16" or smaller ballnose for really good detail. You might also want a tapered ballnose bit.
    For plastics, get some 1/8" and 1/4" "O" flute bits. Depending on the size of your parts.
    For wood, you might want some downcut spiral router bits. They leave a cleaner top edge and splinter less. But you'll want upcuts if you're making deep cuts.
  1. New Machine Build- Starter Machine
    By O'Seanski in forum DIY CNC Router Table Machines
    Last Post: 01-19-2009, 01:24 AM
  2. Starter Kit Advice
    By minium in forum Engraving Machines
    Last Post: 10-25-2008, 03:03 PM
  3. Starter Bit Set Recommendations
    By 3D Robotica in forum General Material Machining Solutions
    Last Post: 07-23-2007, 03:18 PM
  4. New starter to CNC
    By Simon_18 in forum General Metal Working Machines
    Last Post: 06-09-2006, 12:09 PM
