Results 1 to 4 of 4
Thread: Radial depth
    Nov 2011
    lithuania
    Radial depth
    Hi The radial depth of cut should be less than 0.25 of the diameter of the end mill.What does that mean?
    Nov 2011
    lithuania
    Jun 2011
    united states
    If you are side milling the depth of cut should be no larger than 1/4 the diameter of the endmill you are using. Example: 1/2 inch endmill would be 1/8 depth of cut. Note that this does not mean in the z axis but in the x or y.
    Nov 2011
    lithuania
    Quote Originally Posted by deneyeone View Post
  1. CNC Radial Engine
    By MMT in forum I.C. Engines
    Last Post: 04-27-2012, 12:56 PM
  2. Need Help!- Axial and radial depth of cut
    By atlantic23 in forum General Metalwork Discussion
    Last Post: 03-23-2011, 07:57 AM
  3. radial 5 cilynder
    By tonycorse in forum I.C. Engines
    Last Post: 04-18-2010, 03:06 AM
  4. Need Help!- Radial Groove
    By skmetal7 in forum PTC Pro/Manufacture
    Last Post: 04-04-2010, 09:01 AM
  5. radial depth of cut
    By jeremyinnys in forum General Metalwork Discussion
    Last Post: 12-07-2006, 01:59 PM
