Results 1 to 4 of 4
Thread: Form drilling
    Apr 2010
    Form drilling
    Hello i am looking for a 1 inch drilll with a .5 rad must be 8 inch min length
    can be carb or indexiable . It drills form after spade drill drills hole this operation is in a lathe. What are you using ? Any recommendiations ?
    Material is 9310. Cheers !
    Jul 2009
    Drill/Form Tool
    Quote Originally Posted by Scotty27 View Post
    Hello,
    Welcome to the world of machining! Put your Big Boy pants on and walk over to the pedistal grinder and grind a .5 corner radius on a 1" daimeter drill. If the world was driven by you youngsters then we would still be using stone wheels and wooden axels.
    Good Luck
    Sep 2011
    England
    What is 9310? If it is brass or aluminium use a D bit
    Feb 2011
    united states
    .5 Rad Drill
    I make special tooling. Check my post! If you have any needs email me toolmacker4u@hotmail.com I will quote you a price. If you have the drill i will put a radius on the tip to cut to center 1pcs 80.00 2 pcs 60.00 each. I recommend pre drill first then finish with form drill.
  1. Problem- form drilling 4330
    By shrektaylor in forum CNC Swiss Screw Machines
    Last Post: 07-13-2010, 12:23 PM
  2. Need Help!- Spot Drilling/Center Drilling Steel 55 HRC
    By JWB_Machining in forum General Metalwork Discussion
    Last Post: 03-11-2009, 02:35 PM
  3. Form 20 A EDM
    By ramigary in forum General Waterjet
    Last Post: 11-27-2008, 03:31 PM
  4. drilling and drilling cycles tutorial
    By wmorre in forum General Metalwork Discussion
    Last Post: 10-18-2006, 07:30 PM
  5. CNC Router Kit Form
    By xtaffy in forum DIY CNC Router Table Machines
    Last Post: 02-17-2005, 04:01 PM
