Results 1 to 2 of 2
Thread: Cutting M.D.F...
    Nov 2009
    u.k
    Cutting M.D.F...
    Anybody know where I can get (within the U.K) a bit to cut 18mm M.D.F. I've tried 1, 2, 3 and 4 fluter bits inc. carbide and they all seem to burn, I've experimented with slower spindle speeds, and faster axis speeds with no joy . Is there a special bit I need like the acrylic cutters?
    Any help would be good!!
    Mar 2003
    Shelby Twp, MI....USA
    Any router bits made to cut wood should cut MDF just fine. If it's burning, you're still going much too slow. You probably need to at least double your feedrate.
    What rpm and feedrate are you using?
  1. How do you decide cutting speeds for cutting plexiglas?
    By angryManLT in forum Glass, Plastic and Stone
    Last Post: 05-04-2011, 10:28 AM
  2. Malaysia's Local Flame Cutting CNC, Plasma Cutting CNC Manufacturer : RobotshopCNC
    By MechanoSystems in forum Product and Manufacturer Announcements
    Last Post: 01-25-2010, 08:53 PM
  3. Newbie- Newbie needs help! cutting acrylic, and double cutting? 3040 machine
    By stephaniehamer in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 06-29-2009, 04:37 PM
  4. Can Watr jet cutting and laser cutting make endmills obsolete?
    By slashmaster in forum Benchtop Machines
    Last Post: 06-18-2009, 05:07 PM
  5. I need help about cutting heads which apply to apparel pattern cutting machine
    By sheepgrass in forum Mechanical Calculations/Engineering Design
    Last Post: 05-12-2006, 02:09 PM
