Results 1 to 4 of 4
Thread: lost on how to go about tooling on project
    Jul 2011
    hi,
    i have a friend that would like me to create a heat sink for him,
    the profile looks like that
    im a hobby machinist that over the years only done simple parts, i know i can create the code for this easy enough but where im getting lost at is the wavy profile, is there already a tool that would help me achieve this?
    any and all help is appreciated.
    Apr 2004
    Oakland CA USA
    You'll need something with an offset
    to create undercuts like that. Picture a shaft with a larger ball on the end. These are commonly made for grinders, although I haven't seen them with the sparser flutes generally used for endmills.
    Another way you could get this effect is by tilting the workpiece after cutting the ridges, so that you can access the sides with a ball-nosed (but not offset) cutter. But you'd have to do this twice, and it would be hard to maintain registration.
    A third way to go would be to have a special form tool made, with the profile of the side of the ridges ground into its edge. This will cost some money, but this guy doesn't think he's getting this odd job done cheap, does he?
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Quote Originally Posted by johnnyr View Post
    hi,
    May 2004
    United Kingdom
    That profile was originally extruded in aluminium, and the extrusion die would have been cut with an ordinary end mill (or possibly wire edm) as it would have the plan shape that you see as as profile. To achieve the same disipating area can your friend not accomodate a shape more suitable for milling rather than extruding?
    Andrew Mawson
    East Sussex, UK
    Jan 2006
    Yes, that was my thought exactly.
    If that "wavy slot" profile gives you (say) 25% more surface area than straight sided slots, how about just increasing the number of slots to gain back the area?
    So, instead of making a series of 1/4" wide wavy slots, switch to 3/16" straight sided slots.
    I'm sure heat sink design is much more complicated than just surface area, but for a one-off part I would want to keep it simple. I guess it depends on what he is cooling and whether a stock part would do the job or not.
    Steve
  1. Replies: 2
    Last Post: 08-09-2010, 11:17 AM
  2. (Free) E-zine coming out soon..Lost foam project
    By drescher3 in forum Casting Metals
    Last Post: 08-16-2008, 04:34 PM
  3. well now that i have it im lost.....
    By pulsar110 in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 11-26-2007, 12:50 AM
  4. Im lost, where do I go from here???
    By ifttinker in forum Syil Products
    Last Post: 01-15-2007, 07:45 PM
  5. Website update - Lathe Project & Fixed Length Tooling
    By Hack in forum Product and Manufacturer Announcements
    Last Post: 06-10-2006, 11:25 AM
