I have an application where i need to use a reamer of 3.9 H7 in a 58 HRC SAE 8620 steel component. Depth of the hole is 6mm. I have a reamer which is TiAlN coated. Can someone suggest me cutting parameters for this ? What could be the expected life of the tool in this hardness ?
thanks a lot
