Results 1 to 3 of 3
Thread: need 12mm or 15/32" ball end with 1/4" shank
    Mar 2009
    Greetings,
    I'm trying to make some 12mm round cuts in Delrin using a Dewalt router. Life would be simple if I could find a 12mm ball nose end mill that has a reduced shank of 1/4", but I haven't even come close to finding one.
    It would seem that all 12mm bits have 12mm shank. I did order a relatively inexpensive one to see if I can turn down the shank in the lathe, but I'm not too optimistic about that.
    I've noticed that 15/32" is probably close enough to 12mm, and being SAE, it would probably be easier to find a 1/4" shank version, but no such luck I'm afraid.
    Does anyone know where I could buy a 12mm or 15/32" ball nose bit with a 1/4" shaft?
    Thanks,
    Rusty
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    Custom is your option.
    www.integratedmechanical.ca
    Registered l u k e's Avatar
    Apr 2005
  1. Double ball nut on a used machine, "gritty"
    By Kingjamez in forum Linear and Rotary Motion
    Last Post: 07-13-2010, 12:45 AM
  2. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport and Hardinge Mills
    Last Post: 08-17-2009, 11:48 AM
  3. 1/8" shank endmill holder
    By CNCMike in forum General Metalwork Discussion
    Last Post: 10-23-2008, 11:58 PM
  4. BattleAxe "aka" Ball and Chain "aka" the wife.
    By ZipSnipe in forum CNCzone Club House
    Last Post: 05-18-2008, 10:53 AM
  5. Need Help!- 8 mm or 3/8" shank straddle knurls??
    By PoiToi in forum CNC Swiss Screw Machines
    Last Post: 05-09-2008, 06:10 PM
