Results 1 to 2 of 2
Thread: Need custom collet source for RotoZip
    Jul 2007
    I use a RotoZip for my CNC router which has been fine for most work I do.
    I only use 1/8" and 1/4" shank tool bits and so I need both size collets.
    The collets that come with the RotoZip are pretty lame.
    I get decent, but not great clamping with the 1/8" shank bits and the 1/8" id collet.
    The 1/4" shank bits and that collet wobble really bad unless I mess around clamping and reclamping the bits to try and get them to center properly.
    I can get ok results eventually, but it's a PITA.
    The problem looks to me, and I am not all that familiar with collets, that both ends of the RotoZip collets are shaped like a barrell.
    They don't have the flat rear profile or the front flared out section like most collets I see.
    I considered changing over to a Bosch Colt Router as my spindle, which looks to be a better tool than the RotoZip, but they only come with 1/4" collets and I would still have to get a 1/8" collet.
    Can I have custom collets made for the RotoZip?
    If so, I am guessing it's probably really expensive.
    Any advice on how to improve the tool clamping precision on my RotoZip?
    Doug
    Jul 2007
    Been a while since I solved this issue but I ended up purchasing a Precise bits collet set for my Bosch Colt and I could not be happier
    Link to precise bits
    http://www.cnczone.com/precisebits_b...s-details.aspx
    It's an awesome collet, the only complaint is that it can be a bit difficult to get the wrench lined up perfecly on the collet.
    Sometimes it just drops into place, sometimes I struggle trying to get the teeth lined up.
    Besides that, it blows away the stock Bosch Colt Collet.
    I set up a page describing my conversion here
    CNC Upgrade
    Attached Thumbnails Attached Thumbnails Need custom collet source for RotoZip-img_7192.jpg
    My CNC projects page
    http://www.el34world.com/Misc/Cnc/CNC0.htm
  1. Rotozip & MDF
    By e13453 in forum CNC Tooling
    Last Post: 04-23-2010, 04:00 PM
  2. New source for custom DXF files
    By custom dxf file in forum General Waterjet
    Last Post: 11-08-2009, 03:27 AM
  3. Custom bending a custom extrusion
    By brokenrinker in forum Bending, Forging,Extrusion...
    Last Post: 12-15-2007, 09:28 AM
  4. Another Source for Collet Bushing Adapters
    By HayTay in forum DIY CNC Router Table Machines
    Last Post: 03-31-2006, 04:53 PM
  5. Rotozip
    By Ursine in forum DIY CNC Router Table Machines
    Last Post: 09-05-2005, 06:05 PM
