Results 1 to 3 of 3
Thread: Indexable End Mill Question
    Jul 2004
    I'm looking at buying a insert end mill. Am I correct in surmising that I can mill a pocket/profile as deep as the L2 dimension? (not in one pass obviously)
    Mill 1-14 - End Mill Cylindrical Shank
    May 2008
    Sure you can do it but with a good jet of compressed air to clear chips from the slot.
    You can even do ramping with this, just verify with the company what is the maximal angle it can plunge in your material.
    Jeff
    Mar 2008
    Are you considering buying that same particular Kennametal M1 milling cutter? If so, are you machining only aluminum? That's what the cutter is made for, good choice if that's your application.
    And to answer your question: Yes. I have used insert shoulder mills like that in the manner you describe for years, and as long as you have (as jeffrey01 said) good chip evacuation you'll be fine.
  1. Center Cutting Indexable End mill And Indexable Drill Mills
    By CDTooling in forum Product and Manufacturer Announcements
    Last Post: 08-22-2010, 05:39 PM
  2. mitsubishi or sumitomo indexable end mill
    By 15mgtar in forum Want To Buy...Need help!
    Last Post: 03-01-2010, 01:06 PM
  3. Would this indexable end mill be a bad purchase for a hobby mill?
    By Oldmanandhistoy in forum General Metalwork Discussion
    Last Post: 03-10-2008, 10:20 AM
  4. Iscar .375 indexable mill
    By mc_n_g in forum General Metalwork Discussion
    Last Post: 08-10-2007, 02:46 PM
  5. Indexable face mill ?
    By Ken_Shea in forum General Metalwork Discussion
    Last Post: 09-28-2004, 11:25 PM
