Results 1 to 4 of 4
Thread: Is there a tap with a pilot bearing?
    Oct 2010
    I am tapping a hole in an aluminum extrusion on a cnc using a rigid tapping setup. The problem is the the pilot hole is not a complete 360. The hole is only 3/4 round and the tap is having a tendency to work its way towards the opening. The tap is an M16 going to 3.25" deep. I was wondering if the tap had a pilot if that would keep the tap concentric with the axis of the hole.
    Jan 2010
    Registered neilw20's Avatar
    Jun 2007
    Question Fill the gap?
    Can you clamp a temporary spoil piece in the gap to equalize the load?
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Gold Member
    Dec 2004
    Newtown, CT, USA
    If you can rigid tap, you can probably thread mill. That shouldn't care about the gap.
    Ken
    Kenneth Lerman
    55 Main Street
    Newtown, CT 06470
  1. Pilot CNC
    By woodworker2 in forum Commercial CNC Wood Routers
    Last Post: 03-19-2013, 01:34 PM
  2. Pilot Pro Ex ???
    By gelaw in forum DIY CNC Router Table Machines
    Last Post: 03-19-2013, 01:24 PM
  3. New Machine Build- New DIY Cnc kit build Pilot Pro
    By catsm58 in forum DIY CNC Router Table Machines
    Last Post: 11-23-2009, 09:03 PM
  4. THC with HV/HF pilot arc??
    By Fiero Addiction in forum General Waterjet
    Last Post: 10-09-2008, 03:31 PM
  5. 3yr old Pilot
    By CNCadmin in forum Hobby Discussion
    Last Post: 03-03-2006, 10:11 AM
