Results 1 to 2 of 2
Thread: Extra-Long End-mill - Dangerous or not?
    Jul 2005
    israel
    Hello.
    I had recently built a homemade cnc machine.
    Currently my spindle is 23,000 rpm router with 1/4 shank.
    My question is - do you think I can use this End-Mill (6 inch long) to cut hard wood with? I'm a bit scared that the bit will just "fly" away or will brake during the job.
    Any thoughts?
    Jul 2005
    Six inches long spinning at 23,000 rpm???
    I do not think that is a good idea. It might run perfectly okay for a while but if the collet was evenly slightly out of true or if the tool chipped so that it was unbalanced you may get bits of carbide flying around.
  1. vendor of extra long stroke dampener for material handling
    By nearbeer in forum Linear and Rotary Motion
    Last Post: 10-17-2009, 12:12 PM
  2. Need Help!- Is this dangerous?
    By QSIMDO in forum Phase Converters and VFD
    Last Post: 04-07-2008, 05:29 PM
  3. Extra long router bits for foam
    By xshaper in forum Product and Manufacturer Announcements
    Last Post: 10-14-2007, 01:45 AM
  4. Extra long router bits
    By whiteriver in forum General Material Machining Solutions
    Last Post: 06-06-2005, 04:21 PM
  5. Need Extra Long Ball End Mills (12"overall length)
    By CADkathy in forum Toolgrinding & Toolgrinding Machines
    Last Post: 02-17-2005, 10:54 PM
