Results 1 to 2 of 2
Thread: What is a good indexing head/super spacer to convert to 4th axis?
    Registered cjjonesarmory's Avatar
    Feb 2009
    I've been trying to figure out what brand and model of indexing head/super spacer (as they call it) would be suitable for converting to a 4th axis for my milling machine.
    I want one that has a chuck instead of just a mounting plate. I know there are chucks that you can mount onto a plate as well, which would also be fine.
    I attempted to convert my small 6" Grizzly Industrial (no name brand really), but it had way too much backlash in the gears. I started to disassemble it and see if I could replace the gearing, but I got tired of messing with it and would rather just get a more suitable one in the first place.
    Only requirements I can think of are that it has to be sturdy, extremely low backlash, and preferably has a chuck instead of a plate. I just figure there are guys in this forum that have done this before and could give me advice on what they used. I already know how to machine mounts and etc for the motors, just don't want to blow my money on an expensive rotary table/index head/super spacer (etc) and find out it won't really work well.
    Thanks!
    He is more machine now than man.....
    Apr 2004
    Oakland CA USA
    If a small one is okay
    I'd suggest the Sherline 4" rotary table (#3700 CNC): http://www.sherline.com/3700cncpg.htm . It has a t-slotted faceplate and a threaded adapter so the Sherline and Taig chucks both fit it, and it comes with a mount for a NEMA 23 frame motor. You can make your own mount for it to run it in the vertical position on your mill. It has a 72-1 gear ratio, and very low backlash. I've gotten a lot of use out of mine, and my customers are pleased with them as well.
    Andrew Werby
    www.computersculpture.com
  1. IH mill head spacer
    By Runner4404spd in forum Industrial Hobbies (Support forum)
    Last Post: 02-08-2009, 11:44 AM
  2. Super Spacer or Rotary Table w/chuck?
    By pkalag in forum General Metal Working Machines
    Last Post: 11-16-2007, 10:42 PM
  3. So I've got this air-indexer... Cushman Air Flash Super Spacer.
    By ralph@nes in forum General Metal Working Machines
    Last Post: 06-25-2007, 03:50 PM
  4. WTB 12" Super Spacer
    By Fudd in forum General Metal Working Machines
    Last Post: 07-14-2006, 03:43 PM
  5. Super Spacer
    By Zumba in forum General Metal Working Machines
    Last Post: 03-21-2006, 07:08 PM
