chances are slim to none of the v bits surviving
cutting steel on your router will depend upon how well built the router is and how you approach your cuts , rigidity is necessary for steel cutting and heat at those rpms will be the thing to beat .
overall if you you have a good system with good tool paths then its do-able , but most likely you'll need high speed toolpaths
LinkBack URL
About LinkBacks
