Results 1 to 6 of 6
Thread: Tool Life
    Apr 2010
    Tool Life
    Hello, this is my first post and I have a common question that doesn't seem to have a viable answer yet. I would like a way of determining my tool life for various tools and cutting operations. Here are my questions:
    1.) What would be my best bet for finding the correct tool life
    2.) How do I know when I exceeded the tool life, will it break, will it be out of tolerance by a few mills, ect
    3.) Is there a standard test I could run to determine it?
    4.) What would be your best guess for tool life with a 1/4" TiN 3 flute end mill cutting a .1" DOC slot into Aluminum 6061 wit a surface speed of 1000, just a ball park here, I know it depends on VERY many factors.
    Thank you very much for your help!
    Jan 2010
    Talking Tool Life
    I do not know about Correct tool life but tool life can only really be determineed by running it until you can see or feel a difference in the cutter edge, chip formation, part surface finish and dimensions being cut.
    If you have exceeded the tool life beyond being dull, at times it may break and your part will be out of tolerance.
    No standard test that I know of mostly due to so many different varibles to consider.
    Pretty hard to give you a " ball park " figure but it should last quite a while.
    Tool life has always been a mystery to solve for many. When cutting aluminum drilling tools will last for a very long time, so will milling tools but this also depends on how hard you are pushing your tools.
    Really, the best way to determine some sort of degree of tool life is to start with a known new tool. Re-sharpened tools will normally not perform like new tools unless you have a cnc tool grinder to re-create the exact previous grind.
    Visually inspect your new tool cutting edges with the naked eye or use at least a 10 X power lighted magnifier. Know what they look like.
    Use your fingers and feel the sharpness of the cutter. Know what they feel like.
    Do these same two things periodically or after every part ran.
    Pay close attention to the chip formation left by your first cuts and if you can, measure the chip thickness.
    Compare these results to later on when you suspect the cuuter is dulling.
    Pay close attention to how much of a burr is left on your part edges.
    When these burrs start growing, is a sign that your cutter is dulling.
    Inspect your part dimensions closely so you can begin to determine when you are seeing variation.
    When you begin to see some part variation you may then also start to see some tool cutting edge changes.
    It will also make some difference to tool life if the slots you are cutting are being formed with a tool with a sharp corner or if it has a factory corner radius on it.
    The actual effective length of the cutter, the tool holder being used and the rigidity of your work piece also can influence tool life.
    I hope this will help shed some light on this topic.
    Monkeywrench Technician DareBee's Avatar
    Jan 2004
    Stratford, Ont. Canada
    Tool runout and coolant solutions/system will be big in the tool life factor. If you have cheap holders that give 1 or 2 thou runout the life will be massively reduced. Same way with coolant, a high pressure, high volume system with proper fluid will make a huge jump in tool life.
    www.integratedmechanical.ca
    Registered Astonlee's Avatar
    Nov 2008
    United Kingdom
    Question Tool-life?
    What type of machine, control, coolant, and toolholders are you using?
    Apr 2010
    Its a Haas office mill, OM2 30,000 RPM spindle with ISO 20 taper tool holders that are spun and drilled to ensure balance. Tthe coolant is called Kool Mist formula #77 mixed with water and I'm using it as flood coolant
    Registered ImanCarrot's Avatar
    Nov 2005
    UK
    In addition:
    Climb milling will make your tools last longer than if you're Conventional milling- Conventional "rubs" the material and dulls the end mill.
    You can tell a hell of a lot about when a tool is on its way out just by gently running your finger over it as 78nova says- not very quantifiable, but you do get a feel for it, much like sharpening a knife or a chisel, you eventualy get a "feel" for it.
    I love deadlines- I like the whooshing sound they make as they fly by.
    1. Renishaw tool offset / break probe and tool life management
      By mcash3000 in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-20-2010, 10:14 PM
    2. Need Help!- Tool Life
      By gmilosevic in forum General Metalwork Discussion
      Last Post: 01-04-2010, 10:08 AM
    3. Need Help!- CBN tool life?
      By Pontiff51 in forum General Material Machining Solutions
      Last Post: 02-27-2009, 07:15 AM
    4. Tool Life
      By stampman in forum Fanuc
      Last Post: 07-31-2007, 02:30 PM
    5. Tool life
      By Muzzy in forum CNC Tooling
      Last Post: 04-11-2007, 05:47 PM
