Results 1 to 3 of 3
Thread: Whirl Thread cutter
    Nov 2008
    Czech
    Whirl Thread cutter
    can somebody recommend me whirl thread cutter for hardened steel?
    I found only for stainless and titaniun: http://www.zecha.de/html_en/whirl_thread_cutter.html
    Jan 2010
    Talking Thread Milling
    The name you mentioned " whirl cutter " I believe is a trade name for that specific brand of cutter.
    Before this, I had never heard of whirl cutters. Your link showed them being used in the dental field.
    Check out Scientific Cutting Tools website, www.sct-usa.com
    We buy our thread mills or thread hobs as we call them from them.
    We are using solid carbide spiral fluted thread hobs with TAILN coating in 15-5stainless with good results and tool life. These work well in stainless so they should work well in your hardened steel. Our tools are set in shrink fit holders.
    You never mentioned what size threads you were cutting?
    Nov 2008
    Czech
    YES, :-) "Single profile thread cutter"
    Our company is specialized in EDM machining. We have HSC mill for making electrodes and direct milling of hardened steel.
    I am looking for faster way how to make thread in hardened steel than EDM.
    I tried drill up to 65 HRc from FRAISA and it works excellent, i have also tap for 60 HRc, but dont tried it yet, because i am affraid of tool breakage.
    I have experience with single profile thread cutters in aluminium (Zecha tool). It is absolutely safe to make thread and tool is more universal (internal, external, i also used it for making grooves with undercut), so this is the reason why i am looking for coated variant for hardened steels of this tool.
    In the most cases we make therads from M6 up to M8.
  1. Problem- T SLOT MILLING CUTTER PACKAGE 5 (ON WALTER CNC CUTTER GRINDER)
    By dharschman in forum Toolgrinding & Toolgrinding Machines
    Last Post: 09-13-2010, 01:25 PM
  2. Another cutter thread
    By justCNCit in forum DIY CNC Router Table Machines
    Last Post: 08-25-2009, 06:29 PM
  3. Tool & Cutter Grinder and Wire Cutter Plans
    By newport in forum CNC Wire Foam Cutter Machines
    Last Post: 04-17-2009, 05:15 PM
  4. Acme Thread, Ball Screw Or Belt Drive for Laser Cutter/Engraver?
    By pyrofx in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 04-08-2009, 04:59 AM
  5. Thread Mill Cutter Help Needed
    By TZ250 in forum General Metalwork Discussion
    Last Post: 10-05-2006, 01:40 AM
