Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 01-23-2010, 12:32 AM
AvtekMfg is on a distinguished road
Star VNC 32
Hi.
We have a 1986 Star Vnc 32. We were changing a 3/8 bar and didn't close the collet and hit start. The material was pushed up a few inches and the monitor and panel went out. It was if the estop was tripped. My partner had a friend look at it but they couldn't figure out what is keeping it from coming back. They said it's like the reset button is stuck. The button wasn't pushed when this happened either.
I can post more info if someone has any thoughts on this.
Thanks,
Michelle
Old 01-24-2010, 01:31 PM
PixMan is on a distinguished road
Start by disconnecting the main power supply switch. Open the electrical panel door and press every reset button, heater and circuit breaker you can find, then check every fuse. There's got to be an overload tripped in there somewhere.
Need Help!- Star VNC-12 tech18* General Metal Working Machines 0 11-22-2009 06:36 AM
Need A Quote- Star SR20 jrob69 Employment Opportunity 3 08-20-2008 11:52 PM
Help with Star SR20RII (Please) mrtedzr General CNC (Mill and Lathe) Control Software (NC) 0 08-27-2007 02:12 PM
Star TZ250 Dolphin CADCAM 2 08-27-2007 07:09 AM
Need Star in .dxf rcazwillis General CAM Discussion 12 12-29-2005 05:16 AM
