Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 01-18-2010, 11:15 AM
yoopertool is on a distinguished road
Citizen F20 Over-Sized Collet System?
Does anyone know of a kit which would allow you to run 25mm material on an F20? I just recently purchased a 1984 F20 and have heard that there is such a kit but I havent been able to find it. I think that they share the same castings and everything. Would it be as simple as changing the spindle liners? Thanks.
Old 01-18-2010, 02:38 PM
ProProcess is on a distinguished road
Originally Posted by yoopertool View Post
... Would it be as simple as changing the spindle liners? ...
I doubt it.
If such a kit exsists, your local Citizen distributor should be able to help.
If they're reluctant or unsure, then I'd contact MCC New Jersey.
Someone there should be able and willing to assist you.
Good luck!
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
Old 01-24-2010, 01:37 PM
PixMan is on a distinguished road
If they are built from the same castings in the same way that an L25 is to an L32, it's an easy switch.
You'll need a collet closer and push tube, but the bigger expense is in replacing the rotary guide bushing unit to accept the larger diameter guide bushings. Also, there may or not be a way of increasing size of the sub-spindle, vut yu usually won't need to because it's common to be doing the pick off to a diameter smaller than the maximum stock size.
Call Citizen Machinery America and they can give you all the part numbers you need.
Citizen Adaptive Collet and SMQ Brass? Suisse CNC Swiss Screw Machines 8 11-02-2009 11:38 AM
Need Help!- Re-grinding spindle for new collet system? Stuff-Builder General Metal Working Machines 21 12-18-2008 05:43 PM
Re-grinding spindle for new collet system? Stuff-Builder Knee Vertical Mills 6 12-18-2008 12:09 PM
Where to buy bits & collet system barkster DIY-CNC Router Table Machines 1 12-14-2008 10:16 PM
CITIZEN E-serie (MITSUBISHI system) subalb CNC Swiss Screw Machines 10 01-22-2008 09:16 AM
