Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 12-22-2009, 10:11 PM
Q Special is on a distinguished road
G84 speeds and feed for 5/16 - 18 Stainless
Asking for speeds and feed for ID thread G84.
5/16 - 18 Stainless steel
Citizen L20
Thanks!
Got F.056, but need spindle speed.
Using F drill - Tried Spindle of 560 and part moved in collet.
Old 12-23-2009, 10:30 AM
ProProcess is on a distinguished road
Citizen L20
Thanks!
What series L20 are you using?
What type of Stainless Steel are you cutting?
Are you using a cut or a roll tap?
Are you Rigid Tapping with G84 or using a compression holder?
Control the process, not the product!
Machining is more science than art, master the science and the artistry will be evident.
Need Help!- Engraving Stainless speeds/feeds? GMTool Engraving Machines 12 11-07-2010 12:31 AM
Need Help!- help with speeds & feed jenx General Material Machining Solutions 1 11-27-2009 10:25 AM
Need Help!- 2 speeds plunge feed? Claude Boudreau BobCad-Cam 4 05-08-2008 04:48 PM
Feeds and speeds for 304 stainless bob1112 General Metalwork Discussion 2 04-30-2007 01:21 AM
feeds and speeds for 350 brinell 17-4 stainless bookwurm99 General Metalwork Discussion 2 02-09-2007 11:42 AM
