Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 12-20-2009, 04:33 AM
Deco-Doctor's Avatar
Deco-Doctor is on a distinguished road
Machining Silicon Iron, best tools to use?
I need to machine some parts from silicon iron on a sliding head CNC lathe. Anyone here had to machine this material before and can give me some pointers for the best inserts to use? I can't find much information about cutting this stuff.
I am considering treating it a bit like cast iron and using ceramic inserts for rough and finish turning without coolant.
I need to turn, drill, and bore the parts. For the drills would coated HSS or carbide be best?
www.tornos.com
THINK PARTS - THINK TORNOS
Old 12-20-2009, 04:40 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
I have used TiAlN coated inserts with a Turbo Mill from Seco Carboloy.
Carbide drills with the same coating OSG
If you don't want to buy Indexable Tooling look at Hanita and DuraMill.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 12-20-2009, 08:16 AM
PixMan is on a distinguished road
Assuming you're on Tornos Deco machines, are you using Applitec inserts or ISO standard screw-downstyles?
If screw down, what geometries? Tell me what toolholders you use and I can recommend some good inserts. No question that carbide for everything would be most productive. Grades and coatings will be key. Using ceramics on a sliding headstock machine can be challenging primarily because you'll have a hard time getting near the recommended surface speed rates for those tools.
Old 12-20-2009, 10:34 AM
Hi - Yes the machine is a Tornos Deco 20a. This is a job I have to try and optimise for a customer. He is currently standard ISO tooling, roughing with a Sandvik TCMT 110308 and finishing with a Sandvik TCMT 110302 both in 16 16 square holders.
Bar diameter is 18mm turned down to 11, 15 & 17mm
I don't know the grades of the inserts he is using. I don't think the choice of finisher is very good, may be better with a D shape.
www.tornos.com
Rough IRON bending, picket twister, scrolling, ring rolling & tube notching tools FPV_GTp Metal Working Tooling 3 01-08-2009 06:38 AM
Machining cast iron on TM-1...good or bad? jwknow Haas Mills 18 10-10-2008 09:25 AM
cast iron machining drwc General Metalwork Discussion 3 01-15-2007 10:20 PM
machining angle iron stymye General Metalwork Discussion 14 09-04-2006 12:43 AM
Machining cast iron itsme General Metalwork Discussion 5 07-19-2005 09:45 AM
