| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
Get a hold of Brian Such with Citizen. He is in the Chicago office. He wrote the softward, and can put you on the right track.
__________________ www.atmswiss.com |
| I have used Win-Cnc for engraving for years. Works well, but the sub program is only the cutting code. You must get the tool to the part and ready to cut before the sub program starts. You can also set the direction, size and axis' before you create the code. See the manual that comes with the software. (On the CD) |
G12.1 will do job on face of the part only. You need G7.1 but check your machine see if it avaluable. Post your code on here....... I had played with it awhile never actually engrave part us C-axis cylinder interpolation yet.
__________________ The best way to learn is trial error. |
| You can engrave on the OD if you have milling interpolation (G12.1) you will also need to change to "cylindrical plane" (G16) along with the G12.1. OR you can just use the C' axis commands. Attached are snap shots of the settings in Win-Cnc on how to get the code right for OD etching. N9(ETCH) T0900 G50W-.5905 M18C0 S3=4500M80 G98G0X1.35Z.5T9 M98P1002(ETCHING-SUB-PROGRAM-CALL) G13.1 G99G0X5.0M82T0M5 G50W.5905 T0100X3.5 |
Hmmmm, I could be wrong 'cause it's Citizen machineand it's difference, but as far as I remember as soon as G12.1 turn on, the machine automatic switch/force to G17(X-Y plane) it MUST go in pair or else.
| On the Citizen machines you choose what plane you want to use during G12.1 "milling interpolation" when you choose the "G16" plane you are then using "cylindrical machining" . G12.1- (option)Converts C axis degrees and X axis movement to work like a milling machine. Program X-Y axis and the control converts all the commands to degrees automatically. X and Y are programmed in radius values and zero is at the center of the part, like a milling machine. Tool nose rad comp is also needed to use G12.1 correctly. There are some new options while calling G12.1. We used to have to change parameters to use G12.1 #1125 Mill_AX and #1126 MillC , now we can set these while calling G12.1 . See also G16 below. G12.1 D0 E=C (the D and E= are new to the C/M series) D0 -You can use "C" or "Y" as the virtual axis while in G12.1 The manual suggests using "D1" to use "C" but I don't agree. If in G17 X-Y plane, then I suggest you use "D0" to use Y". Your choice, it makes no difference which you use! If D is not on the G12.1 line then "C" is default. Always have "D" first on the G12.1 line! E=C -This will set the axis number of the system to use as the polar axis. This depends if you are using the gang plate in $1 or the U121B option in $2 or $3. Setting E=C will set the proper axis automatically. If you don't use E=C on the line then $1 C axis is default. For safety, always use E=C (MILL A .3 SQUARE WITH .02R CORNERS) T2500(MSF-150/2." CUTTER) M5 M18C0 G98M83S4=1000 G50U.37W-.25 G0X3.Z.1T11 G12.1 D0 E=C G17 G41G0X.15Y.6 G1Y-.15,R.02 X-.15,R.02 Y.15,R.02 X.15,R.02 Y.1 G40G0X1.5Y0 G13.1 G18G99 M20 G50U-.37W.25 G13.1- cancels G12.1 by setting control of the C axis back to C and H G16- Plane select cylindrical machining. To use this plane you need the option of G12.1 milling interpolation. G16 is used to convert polar C axis degrees to linear Y when machining "J" slots or cylindrical cams. Most of these part prints are dimensioned with linear and radial values, not degrees. Also the prints usually show the part cut and spread flat. Radii are hard to program and adjust without G16 and tool nose radius comp. G41-G42. Programming would be linear "Z Y". The polar "C" axis is converted to a linear "Y" axis. Another use of G16 is to chamfer a cross hole equaly all the way around the hole. G16 (C.15) C= Position of X axis to calculate from if the actual cutting position is different. This is in radial value. C.15 = X.3 (MILL A J SLOT Sample program not tested yet but should work) T600(.125" cutter / 1/2"bar/ to cut .156 slot) M5 M18C0 G98M80S3=2500 G50C0W-.3937 G0X.6Z-.1T6 X.3(to depth of J slot) G12.1 D0 E=C G16 (C.15) G41G1Z-.02Y.078F6. G1Z.1,R.02(or use G2/some controls ,R didn't work) Y.187 G3Z.256K.078 G1Y-.078,R.078 Z-.02 G13.1 G40G0X.6Y0 G50W.3937 M20 G18G99M82 G17- Plane select- X-Y used when milling with "Y" on the Gang Tools G18- Plane select- X-Z normally used. G18 is when power on. G19- Plane select- Y-Z |
| Or... Does it mean that the [code] output does not look right to you? The WIN-CNC engraving software is very simple and straight forward. If you've "answered" all the GUI questions correctly then the code will execute as you've planned. You do not need G12.1 to engrave on the OD. If you employ G12.1 you would need to "answer" the WIN-CNC GUI as if you were using YZ and not CZ and would be more "confusing" the just interacting with the software under "normal" CZ mode. Maybe post the output and/or screen shots of the WIN-CNC GUI for the engraving Good luck. |
| Need Help!- Citizen L20,L25 | humbertocnc2007 | CNC Swiss Screw Machines | 6 | 02-18-2010 06:17 AM |
| Need Help!- CITIZEN E32 6T | karantaba | CNC Swiss Screw Machines | 1 | 09-18-2009 01:55 PM |
| Need Help!- Citizen L25 | appusivadas | CNC Swiss Screw Machines | 4 | 07-16-2009 08:51 AM |
| Looking at getting used Citizen L20 | PoiToi | CNC Swiss Screw Machines | 5 | 06-03-2009 08:55 PM |
| Need Help!- Citizen E16/20 E25/32 Program | gollame | CNC Swiss Screw Machines | 2 | 02-23-2009 07:35 AM |
