Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 12-15-2009, 08:21 PM
EdgeCrusher is on a distinguished road
Citizen M series basket and counter Question
Wondering if there is a #xxx variable for the parts counter and what part it's on. Would like to be able to program the machine using a IF #xxx(counter set at variable) EQ #xxx (part it's on)GOTO69 and instead of the machine dumping the part going to T2200. You could prob us a loop but then the counter would have to be set a what the loop is programmed at. Just wondering if anyone has ever looked into this or done it. We run Older M's from late 90's to the new 3m3's and 3m5's. Thanks
Old 12-15-2009, 08:42 PM
ProProcess is on a distinguished road
Even if there is registry value for the machine counter, you would be better off just coding it with #500 values and and reset after every so many parts.
The machine counter can be reset too easily and your results would/could be upredictable.
If you use #500's and count you could dump every nth part then reset and start counting again.
Good luck
Old 12-16-2009, 06:21 AM
cogsman1 is on a distinguished road
I agree with Proprocess, using the variables will be more consistant.
I am attaching a sample program which was used on the old M1-20 and would work the same on the new controls also. This was using a counter I created to eject parts into a tube, but, once the tube was full, by know amount, I would start ejecting into another tube located in a second turret position.
File Type: txt MULTI-BASKETS.txt‎ (898 Bytes, 41 views)
Old 12-16-2009, 05:44 PM
Thanks for the replies and I will give that a try Cogsman thanks
Series I Homing Question ranchak Bridgeport and Hardinge Mills 10 12-18-2009 05:20 PM
BP Series 2 Pneumatic Question loedward22 Bridgeport and Hardinge Mills 1 07-16-2009 07:42 AM
Boss 5 Series 1 stepper question tpres500 Bridgeport and Hardinge Mills 30 02-18-2007 12:58 AM
Fanuc Series O-M DNC question Blu91Z28 Fanuc 3 06-30-2006 11:45 AM
POtting Balls into the basket---best mechanism? shaiqbashir RC Robotics & Autonomous Robots 6 03-24-2006 11:26 AM
