Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 11-27-2009, 05:22 PM
tenaja is on a distinguished road
Trouble with long pins getting a bow in them
I'm looking for some advice here. I'm trying to make some 1" long BeCu pins that are 1/32" OD, with a 1/4" long x 1mm OD section near the middle... basically your typical screw machine part. The problem I'm having is the part is coming out with a slight bow to it, typically about 2-3 thou of TIR, which is unacceptable (the target is under 1 thou). I'm using a sharp cutting tool (no radius). I've double checked the tool centerline, and tried varying the cut & feed speeds. I've tried material from a couple different suppliers.
Anybody tackled a job like this and made it? Thanks!
Old 11-28-2009, 07:15 AM
MikeMc's Avatar
MikeMc is on a distinguished road
This type of problem has always been tool center, in my experience. If you are using a formed insert (as opposed to a ground one) this could be the problem as well. This is where an Agathon grinder comes in handy. You should get the tool to razor sharp.
www.atmswiss.com
Old 11-28-2009, 09:56 AM
PixMan is on a distinguished road
You're dealing with internal stresses in the part. There may be some residual stress in the raw material, but it's more likely that you're introducing it in the turning operation.
I agree with MikeMc that you should be using a very upsharp edge on the cutting tool, be right on center, cut a little slow in feedrate to avoid generating heat and flood it with cutting oil to help keep it cool.
Even with those parameters in place you may get some bow. The only solution my be to do a supported turn. By this I mean turn just a short length and then bring in the sub-spindle (assuming your machine has one) to grip the part on both ends as you turn it.
Old 11-28-2009, 07:13 PM
thanks for the tips. I've already flooded it with oil so I can hardly see the part--about 4 nozzles worth. I've already tried the centerline...moving it either direction just made it worse (software made it easy). I am already supporting it with the subspindle as soon as possible. I'm using the sharpest ground inserts I can find, and they are much sharper than I can grind, and certainly better than anything a tool grinder has been able make for me. I've got some pretty steep upsharp Iscar inserts, but the smallest radius they came with was .004"... they've got a pretty sharp edge on them, but they are formed.
So what are the best inserts you guys have used?
Old 11-28-2009, 09:09 PM
Try a Ceratip in the PR930 grade. I apologize that I can't recall the chipbreaker designation, but they have a very upsharp edge on a DCGT 32.5x insert and go down to a .001 or .002 radius. This PVD TiCN coated insert (if you can figure out which chipbreaker I'm referring to) should solve this once and for all.
I learned to hate Iscar once I started using Ceratip, WhizCut, and especially the Utilys brands. The Utilys is also a great choice, but is ain't cheap. Call Genevieve Swiss and they can help you. More info at:
http://www.genswiss.com
In fact, if you call Genevieve Swiss and can talk to Jim (the owner), he can probably debug this problem for you easily.
Old 11-28-2009, 09:56 PM
MadMax is on a distinguished road
Could the part get bent during the final partoff operation? Are you supporting the part with the sub during the partoff?
I'm thinking that the part may be getting loaded in a way that bends it if you're supporting the far end and the parting tool pushes thru.
Old 11-30-2009, 03:14 PM
HSPMInc is on a distinguished road
What kind of material is it? And what RPM are you at? I have some little pins that are like that and the answer was lower rpm (like 3000ish i think) and a MICRO 100 tool that I ground myself for turning.
Also, does it bend it up if you just run the main side and don't pick it off with the sub? Could your sub collet/ejection pin be mucking it up? At that dia. any mismatch from front to back can mess you up.
Old 11-30-2009, 04:02 PM
SwissType1's Avatar
SwissType1 is on a distinguished road
UTILIS offers an insert with a ZERO RADIUS tool nose for problems like this. The edges are also peripherally ground producing a very sharp cutting edge. UTILIS calls is the "Multidec-TOP"
Check them out here:
http://www.genswiss.com/multideciso.htm
Old 12-01-2009, 04:24 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Are you using Ground Material?
Try tightening your Guide Bushing a little. Your Tooling is perfect but also increase the Positive Rake Angle. If your tip winds up wearing out too fast then put at least a .005 TNR and decrease your F&S.
What type and name brand of Swiss are you using?
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 12-02-2009, 02:38 PM
I tend to disagree with "Your Tooling is perfect", because it isn't working.
Why would a .005 tool nose radius work better? In my experience, the bigger the radius the more likely to increase heat and therefore bow.
  #11   Ban this user!
Old 12-04-2009, 10:24 PM
hacdlux is on a distinguished road
applitec makes some verry keen edged tools at reasonabe prices theyre tools are mostly sharp or wiper, with a few radiuses available ive used the 762x-25front turn tools with success doing some verrry slender pins in delrin and aluminum
also have you checked the alignment of your main,gb,sub collet
  #12   Ban this user!
Old 12-21-2009, 01:00 PM
petriej is on a distinguished road
Is your stock centerless ground. I've seen amazing differences in running wrought vs. centerless ground. I don't know much about getting BeCu ground, but we get all of our Ti alloy, CoCrMo, and Stainless centerless ground.
Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
50 pins cable I_V_A_R General CNC (Mill and Lathe) Control Software (NC) 0 11-10-2008 10:15 AM
RFQ: Aluminum pins destroyer125 Employment Opportunity 19 04-10-2007 07:40 PM
ports and pins planescott Stepper Motors and Drives 5 03-24-2006 11:57 PM
Dowel Pins Ursine DIY-CNC Router Table Machines 2 05-27-2005 07:53 AM
Dowel Pins Mr.Chips General Metalwork Discussion 13 02-01-2004 04:00 PM
