Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 10-25-2009, 03:01 PM
Chuckforce's Avatar
Chuckforce is on a distinguished road
Citizen Knockout's (aftermarket)
I found a company that makes aftermarket knockout tips for the Citizen knock out rod. They call them deflecto tips because the deflect the air or high pressure out-wards. This would really wash the chips out
They sent me a pdf sheet on them.
http://www.verosllc.com/VerosSwiss/
Here is a video of it.
They said they are also making Drover nuts for the L20 series 4 (non-windows) & 5 & 7(windows). remember the old wrench type on the 3 & 4 series? That always got buggered up.
Citizen wants an arm and a leg for anything now.
Old 10-25-2009, 04:02 PM
PixMan is on a distinguished road
Looks nice, but every shop I've ever worked at made their own blanks for ejector pins. There's are so many configurations of workpieces that it just make sense to do it this way. Some parts are thin-walled and need a pin very close to the pick-off collet diameter, other parts need to be pushed out from a surface inside a counterbore, etc.
I've made some pretty fancy ones too, with holes like that for either air or HP coolant. Many end up in the part's "job box", a few were more generic and could go into the big drawer of miscellaneous ejectors.
Old 10-25-2009, 07:26 PM
Chuckforce's Avatar
Some will ,but many simple cobble something up that does not have passage for hp oil or air.
It is the most cobbled thing in many shops and I have seen them all . From wooden dowels, to 8mm socket head cap screws ground on a hand grinder.
This seems like a good place for shops to go to. They have them in many sizes, and even sell an emergency blank that can be turned down on a tool room lathe and the brass tip (deflector) screwed in to it.
Need Help!- Citizen L20,L25 humbertocnc2007 CNC Swiss Screw Machines 6 02-18-2010 06:17 AM
Need Help!- CITIZEN E32 6T karantaba CNC Swiss Screw Machines 1 09-18-2009 01:55 PM
Looking at getting used Citizen L20 PoiToi CNC Swiss Screw Machines 5 06-03-2009 08:55 PM
is there a aftermarket 5-axis spindle head? hydrospin01 General Metalwork Discussion 1 05-08-2009 01:51 PM
coolant pump control - aftermarket MrMudd Haas Mills 8 03-08-2006 06:24 PM
