Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 08-31-2009, 01:35 PM
ChristianK is on a distinguished road
Complex part with too much deburring...ideas are nice
Running a fairly complex (TINY!!!) part in titanium. Plus or minus .0005" demensions and alot of burrs. Main problem is using a threadwhirler with a tapering thread. Since the threadwhirler has a constant depth of cut, when it starts to taper up it leaves just enough of a burr that when i return it it rolls over and doesn't cut.
This problem has evaded me for a loooong time and there has to be a solution. Only way I can see; however, is using a turning tool to get into the thread grooves and put a chamfer on the leading edge. That or change the threadwhirling insert's geometry.
Old 09-02-2009, 07:13 AM
PixMan is on a distinguished road
When I made titanium (6Al-4V) bone screws using a thread whirling attachment on a CNC screw machine, I would always turn the tapered nose of the screw frirst, mill any slashes needed at the nose, then thread whirl with cresting inserts. I never had any burrs, but we did polish the bone screws in a secondary operation to make them ultra-smooth.
Old 09-02-2009, 07:32 AM
Can't turn them before as the parts are 2+ inches long of taper and would fall out of the guidebushing / not have enough land to make the part rigid enough to whirl. On parts I can turn them I do and it works quite well; however, this one I cannot.
Old 09-03-2009, 09:55 PM
hongjianming is on a distinguished road
you can test this way,turning a 12.0mm length first, threadwhirling again, than deburr untill finish all length.
Old 09-03-2009, 10:32 PM
Thermal deburring, try Googling it. Also Cryogenic deburring, tumbling, electro-deburring.
What is the most complex cool part you have cnc machined on your benchtop mill? pete from TN Benchtop Machines 67 01-22-2010 11:12 PM
Any ideas on how to reduce chatter in hard part levelzero General Metalwork Discussion 10 07-10-2009 08:49 AM
How would you build this part? - complex shape hlp plz Rich05 Solidworks 15 07-14-2008 10:08 AM
Help Modeling a Part w/ Complex angles nlh Alibre Design 14 09-20-2007 04:31 PM
Any ideas how to scan and trim this part.... Normsthename Digitizing and Laser Digitizing 17 02-27-2007 01:35 PM
