Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 07-07-2009, 02:53 PM
chunkymonkey is on a distinguished road
eggshaped post
people,
i am running a citizen m32 and trying to mill a simple post/boss on a part and the darn thing is eggshaped. a half thou wouldn't bother me, but i am looking at .003" i have reprogrammed this thing 6 ways to sunday and nothing has worked. my tools are on center, new endmills, different speeds and feeds. any ideas?
Old 07-07-2009, 07:52 PM
PixMan is on a distinguished road
What diameter are you trying to mill? I ask so I can understand what percentage of the total dimension that .003" represents. Which axiis are you using to make the feature?
Old 07-08-2009, 01:14 AM
UK-Engineer is on a distinguished road
Egg shaped post
Hello
Sounds like your Y to Z axis ratio is out. If not code specific this could be caused by you programming Y axis co-ordinates in radiall as opposed to diametrical. Citizen M32 series 2 used radiall values on Y1 axis whilst series 3 and newer the user can select via MC Strct page
If this is not the case then then if you let me know code and size required i can hopefully help
Old 07-08-2009, 06:19 AM
it is milling in the yz plane. it is a .125Ø post in 303ss material.
Old 07-08-2009, 08:09 AM
ProProcess is on a distinguished road
If you are using Z1 it could be that the Guide Bushing needs tweeked...
If the feature seems good in Y but smaller in Z then GB too tight.
If the feature seems good in Z but large in Y the GB is too loose.
When everything is right, they still do not produce perfect round post or holes.
HTH, Good Luck!
Old 07-16-2009, 10:29 AM
Shadow_CMA is on a distinguished road
Sometimes the radius in the program might need to be tweeked, are you using G12.1, or are you selecting the proper plane select (G19 Y-Z plane).
Shadow
CMA Service
Old 07-17-2009, 09:10 AM
cogsman1 is on a distinguished road
If you could post the code we could rule that out.
ALSO the "R" and "P" values you are using.
Need post Delcam PowerMILL post for Hardinge VMC 600 II with Fanuc Series oi-MB littlem Post Processor Files 0 10-26-2006 04:59 PM
