Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 06-23-2009, 06:49 AM
maximusek is on a distinguished road
engraving on swiss type machine
Looking for some info about roller imprinting or any solution to engrave few characters around the surface (OD 7.8mm) using swiss type machine. Does someone do anything like that?? Cycle time is critical, whole part is done in 45s so engraving operation cannot take too much time. Thank You for any tip or vendor adress/website.
Old 06-23-2009, 05:05 PM
UK-Engineer is on a distinguished road
Hi there
Engraving option as you say is probaly too slow for your requirement. We use roll markers from German company Hommel & Keller here in the UK - Just plunge on and rotate C axis by required amount.
US Distributor according to website is
RSVP Tooling, Inc.
133 West 61st Street
Westmont, IL 60559
Telefon: 001 630 719 9519
Telefax: 001 630 719 0012
Email: Sales@rsvptooling.com
Internet: http://www.rsvptooling.com
Good luck
Old 06-26-2009, 10:02 PM
JimW is on a distinguished road
We use Sossner Roll Stamps. I usually use the C axis so I can orientate the stamp to other features on the part. Doesn't take more than a couple of seconds.
Old 06-27-2009, 06:17 AM
PixMan is on a distinguished road
That's the one I used too! Thank you, I couldn't think of the maker.
The Star SR20's that I used it on were 1st generation though, and didn't have C-axis spindles. I was able to use the Sossner roll stamps at slow (200rpm) spindle speeds though. No problem putting a company name and logo around 270 degrees of a .300" diameter. It took a little effort/time to get it setup, but ran well.
http://www.sossnerstamps.com/
I had also found this company for the O.P.:
http://www.infinitystamps.com/roll_dies.html
Old 04-29-2010, 08:07 PM
congo is on a distinguished road
Hi Guys,
This is my first post, so bear with me.
Do you guys know if there is a roll stamp that will stamp not on the circular, but on the longitudinal. I have a Tsugami B26, and I would like to roll stamp vs using a hydraulic stamp. Just stop and lock the spindle and lower your X and feed Z to get the "roll stamp" to stamp the material. I would be stamping hex stock so it would be a flat surface that I would be stamping.
Let me know if anyone has heard of such a set up, or I'm dreaming.
Thank You
Congo
Old 04-29-2010, 09:32 PM
Check with Sossner. They've got everything when it comes to roll stamping.
http://www.sossnerstamps.com/about/
Old 05-02-2010, 02:06 PM
I'll check that out. Thank You for your help.
Wanted: Swiss-Type Star SV-32 Parameter Jung Fanuc 4 06-23-2010 12:38 AM
Cold drawn material for Swiss type machines? arobustus CNC Swiss Screw Machines 5 06-07-2009 09:48 PM
Swiss-Type Tooling Deal SwissType1 CNC Swiss Screw Machines 4 01-21-2009 09:43 AM
Wanted: Swiss-Type Star SV-32 Parameter Jung CNC Swiss Screw Machines 0 06-11-2008 06:55 AM
Not round pieces Swiss-Type Miyano Screw Machine gakor General Metalwork Discussion 2 02-18-2008 08:30 AM
