Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 06-03-2009, 09:06 AM
arobustus is on a distinguished road
Cold drawn material for Swiss type machines?
I know I have see ads from suppliers who supply cold drawn material in tolerances compatible with Swiss type machines. I have also seen them at Eastec. However, I can't locate my information about who they are. Can anyone help me out with this? I am interested in 303 SS.
Old 06-03-2009, 01:42 PM
ProProcess is on a distinguished road
schmolz-bickenbach SMQ material
Try this
HTH
Good luck!
Old 06-03-2009, 11:59 PM
MikeMc's Avatar
MikeMc is on a distinguished road
Originally Posted by ProProcess View Post
Try this
HTH
Good luck!
I agree, we but a lot from them, and are quite happy with the results!
www.atmswiss.com
Old 06-04-2009, 09:31 PM
PixMan is on a distinguished road
I'd been in Swiss turning for over 16 years before moving to another type of job. Once we started using Ugitech stainless steels (primarily their 303XL), the Cincinnati centerless grinder collected dust. Great stuff!
Old 06-07-2009, 07:53 PM
CarsonD's Avatar
CarsonD is on a distinguished road
I'm thinking I can remember running a 303 job with cold drawn material that worked better than ground stock.
It was the regular sort of pitted looking cold drawn and if you sorted the size carefully it would run the job at 170 SFM.
Switching back to ground material would run at 120 to 140 SFM.
I think the scale on the cold drawn sort of helped the bushing stay clean. The ground stuff wanted to seize and had plenty of nice fresh surface to do it with.
Old 06-07-2009, 09:48 PM
Wow....S_L_O_W....compared to what I ran with cold-rolled Ugima 303XL! In fact, I ran their 316L at more than 2x that with the right carbide. I used to run their 303 at 600 to 850 sfm. (I'm out of screw machines now though, so I haven't run it in about 2 years.) Ugima 303XL also comes in looking smoother than much of the ground stock I ran.
Of course, I was running machines with rotary guide bushings, not static. Back when I ran those, I was at speeds similar to what you run. BIG difference in productivity when you can run the higher speeds.
Wanted: Swiss-Type Star SV-32 Parameter Jung Fanuc 4 06-23-2010 12:38 AM
Swiss-Type Tooling Deal SwissType1 CNC Swiss Screw Machines 4 01-21-2009 09:43 AM
Wanted: Swiss-Type Star SV-32 Parameter Jung CNC Swiss Screw Machines 0 06-11-2008 06:55 AM
Swiss turn material scook179351 CNC Swiss Screw Machines 8 05-11-2008 12:37 AM
New CNC Swiss machines from stock & Rep npkaye CNC Swiss Screw Machines 0 10-02-2007 11:02 AM
