Does Hangsterfer's make non-chlorinated oil for swiss type machine?? If not, do You Guys know some good not-chlorinated oil for swiss (machined material steel 1045 thru 9310). Thanks
Valenite recently introduced a new line of straight cutting oils. There are 3 types. The VP505 is a nearly clear, lightweight oil for grinding and machining of non-ferrous materials, non-chlorinated.
The VP520 would the one I'd choose for your application, a light yellow-colored low-odor non-chlorinated oil for all materials, though I'd consider adding their "Additive 17" lubricant enhancer for cutting high-temp alloys and copper.
Lastly, the new VP528 is a chlorinated heavy oil for heavy machining os such as broaching, gear hobbing and shaping to name a few.
