Results 1 to 5 of 5
Thread: Sub-Spindle Ejector for Tsugami NP-20
    Nov 2008
    Cool Sub-Spindle Ejector for Tsugami NP-20
    I have purchased a Tsugami NP20C and the mechanismthat attaches to the sub-spindle so a completed part can be ejected into the parts catcher is missing. Not sure what it looks like.... assume it is something I can make. I have contacted REM Sales and they would have to request prints from Japan to make these parts. I am assuming there is a couple of bushings.... a bracket and a rod to attached different tips to depending on the material that is being used. Can anyone help????
    Apr 2009
    NP20 ejector
    This ejector is made up of a hollow rod, 2 bushings and a Dublin rotory coupling, this fits into the back of the sub spindle, the Dublin coupling has a 1/8in pipe connected to it and air or liquid flushes the collet out, the 1/8 pipe also keeps the coupling from rotating and allows the rod to rotate with the sub spindle by means of a bracket.
    Nov 2008
    Thanks for the reply
    Tsugami Man.... Thanks for the reply.... any idea where I can get some measurements so I can fab up the needed parts? Also, do you know the M Code that fires the air blast. Found the line that should be attached.... talk with a helpful fella from Tsugami said M27 or M28..... neither of those work and it is not shown in the manual.... Thanks
    Apr 2009
    NP20
    I will try to get dim and pics tomorrow and send to you, i have a NP32 that i am currently rebuilding and the ejector is out of the machine. send me an e mail to mjmmachine@hotmail.com that i can reply to with pics.
    Feb 2009
    india
    Hi Tsugami man,
    Even i have NP 32 and also don't have the ejector. Can you help me?
    also i need help in bar feeding, i have ALPS bar feeder with this machine, can you tell me what m codes or sub program should i use at the end of the program. Can you send me the structure of it.?
    Thanks in Advance
    chetan
    primoris_engg@yahoo.in
    1. Ejector pin grinding/cut off machine?
      By Chuck Reamer in forum Moldmaking
      Last Post: 10-15-2011, 06:58 AM
    2. Newbie- Tsugami T-SPD
      By rmcclane in forum Want To Buy...Need help!
      Last Post: 10-25-2008, 03:20 PM
    3. Ejector question - electric machines
      By dav612 in forum Moldmaking
      Last Post: 02-15-2008, 03:48 PM
    4. Replies: 25
      Last Post: 04-13-2007, 08:01 AM
    5. Ejector pin machining? Length setting?
      By DomB in forum Moldmaking
      Last Post: 12-30-2006, 04:21 AM
