Results 1 to 6 of 6
Thread: Swiss Material Requirements for Centerless Ground Stock
    Oct 2007
    Hello,
    I was ask to put together a form on the material requirements for our swiss lathe machines. To send to our vendors. All I know is how to program them and set them up but now I am stuck with this. I also know if we use centerless ground stock we eliminate a lot of the problems we are having now. Where I use to work we use 12ft long +/-.0005 dia. and must meet print ASTM. This all started when we receive 3/4" bar stock that mic .7595. I was looking at there certs and we didnt have any specifications on the material certs. So now i am stuck putting some kind of form together. We are going to get our material sent out to get centerless ground from now on. If some one has a form I can reference on what specifications I should be looking for Please send it to my email address -tejano4life72@yahoo.com. I just need to look at something to help me get started and make my own.
    Thank you,
    Tejano
    Dec 2008
    england
    hi,
    i would suggest you look into automatic guide bushes this could save you a lot of cash in the future that way you dont need to purchase ground stock for its consisitant dia
    regards
    izhammer
    Oct 2007
    izhammer,
    Thanks for the suggestion, but this company wants to go with centerless ground material. I tried already.
    Jan 2009
    Smile
    I would suggest +/-.0003 with 32 micro finish. Also a chamfer on one end of the bar would help.(chamfer= 25% of stock dia).
    Oct 2007
    citizencnc,
    Thank you for the suggestion and the chamfer idea.
    Dec 2005
    In the early days I would buy ground stock for our Swiss Machines but have been able to eliminate that by getting the material from Schmolz & Bickenbach(formerly Ugine). I routinely mic the bars and get less than .0005 variation end to end. Another upside is they chamfer both ends of the bars.
    1. Machining Ground Flat Stock - Tool Steel
      By cmnewcomer in forum General Metalwork Discussion
      Last Post: 02-02-2009, 10:11 AM
    2. Not plunge into stock material
      By cncuser1 in forum Mastercam
      Last Post: 07-26-2008, 11:00 AM
    3. Swiss turn material
      By scook179351 in forum CNC Swiss Screw Machines
      Last Post: 05-11-2008, 01:37 AM
    4. Need Help!- Working with stock thickness material.
      By svatchi in forum Work Fixtures and Hold-Down Solutions
      Last Post: 03-29-2008, 09:36 AM
    5. New CNC Swiss machines from stock & Rep
      By npkaye in forum CNC Swiss Screw Machines
      Last Post: 10-02-2007, 12:02 PM
