Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 01-14-2009, 02:59 PM
chunkymonkey is on a distinguished road
rapid c axis movement slow
I have a Citizen M32. I am trying to "shave" an ID detial. Basical it is a 21.7mm square with corner radii. except the radii are a full diameter of 23.2mm. when i go to do full rapid "H" value increments, the machine does no go rapid. it is very slow. Below is a portion of the cycle. whole program to big to reasonably post. thoughts?
X.8562W.000024H.1
X.8562W.000024H.1
X.8562W.000024H.1
X.8562W.000024H.1
X.8562W.000024H.1
X.8562W.000024H.1
X.8562W.000024H.1
X.8562W.000024H.1
X.8563W.000024H.1
X.8563W.000024H.1
X.8563W.000024H.1
X.8563W.000024H.1
X.8564W.000024H.1
X.8564W.000024H.1
X.8564W.000024H.1
X.8565W.000024H.1
X.8565W.000024H.1
X.8566W.000024H.1
X.8566W.000024H.1
X.8567W.000024H.1
X.8567W.000024H.1
X.8568W.000024H.1
X.8568W.000024H.1
X.8569W.000024H.1
I HAVE TRIED TO DO IT ANOTHER WAY WITHOUT THE W AXIS
ANY HELP WOULD BE GREAT!
Old 01-15-2009, 04:53 PM
cogsman1 is on a distinguished road
I don't see a "G0" in your sample of code. Is it in the part that is missing? If not then you are feeding.
Old 01-20-2009, 09:14 PM
Gilla#77 is on a distinguished road
are you doing milling interpolation? it is my understanding that when you are milling and are using the "C" axis in your moves that the "C" axis takes over on feedrates. your feeds will be in degrees per minute. i saw no "G0" in your codes so i assume your feeding. your feedrates will be like "F1000.0" as in 1000 degrees per minute.
Old 01-25-2009, 08:35 AM
billcain is on a distinguished road
C-axis Feed
Gilla is correct. When your feeding the C-axis you need to covert the Feed rate to Degrees per minute which is very high compared to inches per minute. Just remember if your tool path returns to a move that does not include the C axis rotation, you need to reoutput the feed per minute.
Bill Cain
www.parkmaker.com
Old 02-21-2009, 02:02 AM
chetan is on a distinguished road
I think you should use M19 command before indexing then you have to make c axis to Zero then go for your desired orientation. Try it .
I m confuse bet M90 or M19. try both
Need Help!- No rapid on Z Axis with G0 btcoutermash Bridgeport and Hardinge Mills 27 01-20-2009 08:07 PM
Rapid Movement after profile shelburnebri SmartCAM 1 10-01-2008 11:43 PM
O mate M slow rapid rate Phase II diemaker Fanuc 0 10-18-2006 04:08 AM
O mate M slow rapid rate diemaker Fanuc 6 10-09-2006 02:14 PM
Axis Slow Down dighsx Xylotex 34 05-31-2006 08:15 AM
