Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 10-11-2008, 08:15 PM
rdoty is on a distinguished road
Screw Machine or CNC Lathe source needed
I have three small parts that I need in roughly 500-1000 pc quantity.
Part 1 is 300 series SS, .5 dia x 1 in with 1/4-20 x 3/8 male thread on one end and other end profiled in three diameters (0.455, 0.304 and 0.220). These different diameter profiles would use the same form cutter. There is a .5 dia section that is knurled. Would like 300 pcs ea.
Part 2 is a small nylatron shaft, .50 dia x 1.12 long, one end is turned to .340 dia with a 1/4-20 female thread x .5 dp, other end is bored .32 dia x .6 deep. I could do the .32 dia 2nd operation)
Part 3 is acetal (delrin), .75 diameter x 1 in long, one end has 1/4-20 male thd x .35 long, other end has a tapered bore x .35 deep. May be knurled. I could do the tapered bore operation since I already have a setup on my CNC mill.
Don't have a lot to spend but if you are interested shoot me a line and I'll email drawing copies. This could turn out to be a repeat job in larger qty's but right now it's a new product offering with no idea of ultimate volume.
You can email me at ramp@frii.com
Need Source - Tornos Screw Machine Parts kend General Metal Working Machines 1 06-12-2009 03:22 PM
RFQ Lathe/screw machine parts Toggle Employment Opportunity 6 09-28-2007 02:31 PM
cnc lathe or Screw machine??....need some parts heatseekins Employment Opportunity 0 04-13-2006 10:44 AM
Die heads, threading screw machine, lathe... crayner General Metal Working Machines 0 02-01-2006 11:27 PM
RFQ: Lathe or Screw Machine Job lerman Employment Opportunity 3 01-24-2006 05:50 PM
