| CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here. |
Hi all! I have a new part that requires a hole drilled in the end, and then 4x slots that are .010" wide down the part .750. (it's some sort of collet.) It's made from 303 stainless. I was planning on drilling the hole first and then using a slitting saw on one side of the part at a time, since the depth of the slots is greater then the saw will go. Since I was planning on doing only one side at a time, the max. thickness of material that will need to be sawed is about .040". Though the front of the collet will only have a wall thickness of .017... Can anyone help me with a good feedrate and speed of the saw? the saw is solid carbide, .590" in diameter, and has 64 teeth. Also, i was planning on running the drill back though after sawing to clean up any burrs... would this work? thanks a lot!! |
| Thanks!! the arbor and saw we have is "guaranteed" to have less than .0003 runout.. we will see. =) i get a feedrate od 35 IPM at 2800RPM.... that feedrate seems a little bit ridiculous....Especially for a .010 wide saw. I've never done slitting at the machine before, so i'm pretty in the dark on this. any more help would be awesome! Last edited by PoiToi; 10-07-2008 at 05:10 PM. Reason: More info! |
| Help with slitting saw | evena4 | General Metalwork Discussion | 5 | 08-23-2008 02:09 PM |
| Wanted - small slitting saw blades | watchman | Metal Working Tooling | 3 | 03-14-2008 03:17 PM |
| saw slitting lexan | recoton | Glass, Plastic and Stone | 5 | 07-02-2007 05:54 AM |
| Slitting-slotting saws | Vern Smith | Haas Mills | 20 | 02-27-2007 12:17 AM |
| speeds and feeds for slitting with hss | pimp215 | General Metal Working Machines | 6 | 02-23-2007 05:22 PM |
