Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 09-10-2008, 07:31 PM
EvansMachine is on a distinguished road
Saving your cutting oil
Hello,
what do you guys do to reclaim oil from your chips?
Old 09-10-2008, 11:42 PM
extrem89 is on a distinguished road
We use Barrett chip spinners....
Old 09-11-2008, 01:45 AM
DDM DDM is offline
DDM is on a distinguished road
We use two 35 gal plastic trash cans one inside the other with the inner one having a bunch of holes drilled in the bottem to let the oil drain out into the outer can and the chips stay in the inner can. Make sure they are heavy duty or they will break on you after time. It's not the best solution but it works.
Carl
Old 09-15-2008, 02:06 PM
machinemike is on a distinguished road
What we do is dump all our chips in a 55 gallon drums. The containers are on rollable lip carts. We drilled small holes in the bottom of the 55 gallon drums. We drilled and put a drain plug in the rollable carts and simply drain it as it gets full. Easy money.
Old 09-20-2008, 12:45 PM
yoopertool is on a distinguished road
Chip spinners get alot more oil back out of the chips. Cutting oil is too expensive to be loosing lots of it through your chips.
saving files with a DWG or DXF casta-baga Mastercam 7 08-06-2008 11:02 PM
saving tools delhierro Safety Zone 10 04-26-2008 06:18 AM
Saving a File utahnorton AjaxCNC Control Products 0 12-28-2006 10:10 PM
Saving the Changes, CharlieM Kellyware CAM 0 01-11-2006 02:24 PM
saving code trevorhinze BobCad-Cam 1 08-05-2005 09:42 AM
