Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Swiss Screw Machines
CNC Swiss Screw Machines Discuss CNC Swiss Screw Machines here.
Old 08-12-2008, 05:10 AM
Kai_DK is on a distinguished road
Fanuc M140 Citizen Machine
Hi.
Im only a carrier for an operator with this problem!
What function does M140 do, on a Swiss lathe type, Citizen with some sort of Fanuc controller?
Regards,
Kai
Old 08-12-2008, 07:56 AM
cogsman1 is on a distinguished road
The "M140" command makes the "Z2" slide come forward to use the 3 tools located next to the sub spindle. This is a parameter position and will rapid to it. When you are done with those tools you will command an "M141" to send the slide home(back). When using the "M140" and indexing between the 3 tools the slide will NOT retract it will just slide over to the next tool called. This means you MUST retract the stock (Z-.05) before calling the new tool or you will break tools.
Need Help!- Citizen E16/20 E25/32 Program gollame CNC Swiss Screw Machines 2 02-23-2009 08:35 AM
Citizen K16 programming bvaught CNC Swiss Screw Machines 12 07-03-2008 07:51 AM
pick off on citizen f12 cseely CNC Swiss Screw Machines 2 01-09-2008 12:13 PM
Citizen CAV barfeeders EdgeCrusher CNC Swiss Screw Machines 5 11-03-2007 11:04 PM
How to operate a Citizen FL-42 Twistr General Metal Working Machines 0 12-27-2006 06:23 PM
